misfire
Old Jun 24, 2003 | 05:15 PM
  #31
CHAHONDA's Avatar
corona connessuer
start the car and let it idle. get it up to normal temperature. unplug the maf and if it starts to idle normal then its bad. replace it. that is if it idles rough
Old Jun 24, 2003 | 05:17 PM
  #32
Ninety7GSX's Avatar
No Name Who?
Ninety7GSX has disabled reputation
Did you do anything with your plugs?
Check the gap maybe?
Old Jun 24, 2003 | 05:19 PM
  #33
g S x's Avatar
RIP Chris Schader
g S x g S x g S x g S x g S x g S x g S x g S x g S x g S x g S x
i gapped them to 28.
my check engine light is off now that i replaced the coolant temp sensor. if i unplug the MAS, it wants to stall. thanks
Old Jun 24, 2003 | 05:30 PM
  #34
Ninety7GSX's Avatar
No Name Who?
Without the mas the car will run off of a base map which is normally really rich.
**also you can get away with a slightly larger plug gap if you wanted to especially if you have an ignition.
Old Jun 25, 2003 | 08:40 PM
  #35
import killer's Avatar
Turbo Dodge
import killer is an unknown quantity at this point
u might have verry dirty fuel injectors because my freinds car did the same thing so check ur fuel filter and rail and hope ya get ur car running
screamneagle
Feb 4, 2009 04:17 AM
ShortyzKustomz
Mar 16, 2008 06:36 AM
Acrytet70
Jan 21, 2008 08:32 PM
DomesticDesire
Mar 31, 2006 01:51 PM
Sidewinder20
Mar 28, 2006 10:20 AM
