Problem with idle
Old Oct 18, 2004 | 06:35 AM
tegman96's Avatar
tegman96 has disabled reputation
Default Problem with idle
i installed a set of stage 3 cams in my 96 ls integra i have tried everything to get the car to idle right but it wont under 2000 rpm i have sent the ecu off to be chipped but they said that it will more than likely not fix the problem the tps sensor is operating properly and i am running out of ideas I dont think its the cam timing bc the car makes power up high any ideas will be helpful thanx
Old Oct 18, 2004 | 07:04 AM
Enigma's Avatar
Default Re: Problem with idle
Do you have adjustable cam gears? You will need those to get the right timing for those cams. The stage 3, I take it, have a very large lift, this will cause shitty idles. That's why Honda created VTEC (yay for VTEC), do some reading on the motors and what not.
H23Lude9
Aug 6, 2008 07:52 AM
Bad4life2000
Jan 17, 2008 09:42 AM
2tonehatch
Mar 22, 2006 04:33 PM
LastMinuteRacin
Dec 31, 2005 12:34 AM
The real Ryan
Apr 23, 2003 04:11 PM
