idle problem?
Old Mar 21, 2006 | 05:10 AM
2tonehatch's Avatar
2tonehatch has a spectacular aura about2tonehatch has a spectacular aura about2tonehatch has a spectacular aura about
Default idle problem?
i have a 92 accord wagon, when you first start the car up the rpm's raise a little till the car warms up. once the car is running for a while , the rpm's begin to raise and drop quickly between 1,000 and 2,000 rpm's . then it goes away and comes back after a while when you come to a stop while driving. So, i was wondering what may cause this to happen. any input would be great!!! thanks in advance.
Old Mar 21, 2006 | 05:36 AM
hotmar's Avatar
e46
hotmar hotmar hotmar hotmar hotmar hotmar hotmar hotmar
Default Re: idle problem?
i had the same problem but in my 00 bmw...there was low psi in the cylinders...could be that...if thats the case you can get stuff called RESTORE and mix about 2 cans of that in with an oil change. ... do this again after about 1k - 1500 miles then after that at 4k more....
before you do that get the cylinders psi checked out...
or like someone else did with the same problem, you can clean the throttle body i think it was....there is another thread like this one, check it out.
Old Mar 21, 2006 | 04:26 PM
allmotorSOHC's Avatar
Owner
allmotorSOHC has disabled reputation
sounds like you ivac is starting to go. also you might check for vaccuum leaks.
Old Mar 21, 2006 | 07:38 PM
brown_ricer's Avatar
AWD talon
brown_ricer has disabled reputation
i had the same thing happen to my coupe... its either the fitv ( fast idle thermo valve, tighten the plunger) located on the throttle body, the iacv (located on the intake manifold, you can clean this), or a vaccum leak
Old Mar 21, 2006 | 07:47 PM
Fobby's Avatar
Classified Moderator
Fobby Fobby Fobby Fobby Fobby Fobby Fobby Fobby Fobby Fobby Fobby
yep
Old Mar 22, 2006 | 05:09 AM
DaveXDefiant's Avatar
DaveXDefiant is an unknown quantity at this point
agreed idle air control valve or something of that nature, like dude said you have the little black circle on the intake manafold/throttle body you can use a flat head and rotate it clock wise or counter and it will increase and decrease your idle, that did it for me
Old Mar 22, 2006 | 06:20 AM
Mephisto's Avatar
Mephisto has disabled reputation
agreed
Old Mar 22, 2006 | 06:43 AM
MerF's Avatar
Ghost
x3 on the IAVC or other vac leak.
Old Mar 22, 2006 | 04:25 PM
2tonehatch's Avatar
thanaks for the help guys i will look into that this weekend
Old Mar 22, 2006 | 04:33 PM
KYLE ROSE's Avatar
KYLE ROSE has much to be proud ofKYLE ROSE has much to be proud ofKYLE ROSE has much to be proud ofKYLE ROSE has much to be proud ofKYLE ROSE has much to be proud ofKYLE ROSE has much to be proud ofKYLE ROSE has much to be proud ofKYLE ROSE has much to be proud ofKYLE ROSE has much to be proud ofKYLE ROSE has much to be proud ofKYLE ROSE has much to be proud of
low coolant will do that to but mostly likely iac
H23Lude9
Aug 6, 2008 07:52 AM
Bad4life2000
Jan 17, 2008 09:42 AM
LastMinuteRacin
Dec 31, 2005 12:34 AM
tegman96
Oct 18, 2004 07:04 AM
The real Ryan
Apr 23, 2003 04:11 PM
