Idle problem....
Old Dec 19, 2005 | 03:19 PM
LastMinuteRacin's Avatar
LastMinuteRacin has disabled reputation
Default Idle problem....
Ok heres the deal..i have a 92 prelude w/ a f22a1 and I cant seem to figure out the idle surge problem.The problem exists both when the cars cold and hot,in gear and out of gear. I will pay if somone can figure this thing out or maybe someone could point out a good shop in the hampton/nn area.Im leaning toward it being either a wring issue or the ecu.
Heres a list of things ive done
Tps
Iac valve
Fuel filter
egr valve and gasket
egr control valve solenoid
constant vacuum control valve/egr vacuum control valve
plugs
cap/rotor
air filter
full of coolant/and no air in system
no vacum leaks and the hoses are in correct position
The only codes its throwing are 12(egr lift sensor) and 23(knock sensor)
Thanks
Old Dec 19, 2005 | 08:58 PM
Default Re: Idle problem....
on another note does anyone have gene from tunners edge number or a way to contact him b/c im sure he could figure this out???
Old Dec 20, 2005 | 07:19 AM
連続注入's Avatar
Dont guess, diagnose
連続注入 連続注入 連続注入 連続注入 連続注入 連続注入 連続注入 連続注入 連続注入 連続注入 連続注入
This is just a shot in the dark so dont hold me to it. But from the codes you are pulling Im thining that the EGR valve is stuck open at idle causing your mixture to lean out badly causing knock. Which will set off the knock code.
Like I said, just a shot in the dark. I hate doing internet diagnosis.
Old Dec 20, 2005 | 11:43 AM
Thats what i thought too so i blocked the egr off and still the idle problem exxists....Im goin crazy tryin to figure this out.
Old Dec 20, 2005 | 12:02 PM
CHAHONDA's Avatar
corona connessuer
dont block it off...replace it!
Old Dec 20, 2005 | 12:04 PM
im workin on that. I was hopin it would be a temp fix.
Old Dec 20, 2005 | 12:27 PM
sprack's Avatar
sprack is on a distinguished road
Originally Posted by CHAHONDA
replace it!
i second that
Old Dec 20, 2005 | 01:35 PM
alright ill do that and see if it works.
Old Dec 23, 2005 | 05:42 PM
ok i changed the egr and reset the ecu. The idle problem still exists but now its only ever now n then, and its still jumpy in gear. It is also still throwin a cel 12 and 23 when u go over 40mph ??? What should i try now....
Old Dec 24, 2005 | 02:53 PM
