LS idle problem, help!
Old Nov 14, 2007 | 12:53 PM
kalel's Avatar
Ground Level Imports
kalel has disabled reputation
Default LS idle problem, help!
got a 91 DA teggy and the car will start up just fine, then it slowely idles up to about 3500 rpm and stays around there. what the heck is wrong, i recently put it in, did i mess up the vac lines, or is it just a bad sensor or did i forget to hook something up? PLEASE HELP ME!
Old Nov 14, 2007 | 01:54 PM
Verbal's Avatar
r0tard
Verbal is infamous around these partsVerbal is infamous around these partsVerbal is infamous around these partsVerbal is infamous around these partsVerbal is infamous around these partsVerbal is infamous around these partsVerbal is infamous around these partsVerbal is infamous around these partsVerbal is infamous around these partsVerbal is infamous around these partsVerbal is infamous around these parts
Default Re: LS idle problem, help!
check your voltage on you TPS. check to make sure you throttle cable isn't too tight.
I am not sure if your IACV could cause that, i guess it's possible.
Old Nov 14, 2007 | 02:05 PM
idriveahonda's Avatar
Shooting 63's
Check TPS voltage and throttle cable like ^^ said.
Also might as well do the FITV and IACV as well, pretty simple stuff to do anyway.
Check for vacuum leaks...use soapy water in a spray bottle and spray around the IM, and check for bubbles.
Also make sure that all the air is out of your coolant system.
Old Nov 14, 2007 | 02:16 PM
DORKO's Avatar
Bearded.
brake cleaner works better, b/c you can hear the motor surge a little bit. if there is a leak underneath the intake manifold, how would you see the bubbles?
i personally use brake cleaner/carb cleaner
Old Nov 14, 2007 | 03:02 PM
kalel's Avatar
will check it all....what voltage am i looking for the multimeter to read for the tps?
Old Nov 14, 2007 | 03:18 PM
DORKO's Avatar
Bearded.
fuck i cant remember, one of my buddies just had this problem on his hatch.
ill try and find out asap
Old Nov 14, 2007 | 05:26 PM
Gustav's Avatar
Gustav is infamous around these partsGustav is infamous around these partsGustav is infamous around these partsGustav is infamous around these partsGustav is infamous around these partsGustav is infamous around these partsGustav is infamous around these partsGustav is infamous around these partsGustav is infamous around these partsGustav is infamous around these partsGustav is infamous around these parts
Don't use brake clean if you are in a garage. It puts out highly toxic fumes once burned through the engine. Carb cleaner is fine though.
Old Nov 14, 2007 | 07:15 PM
sohc_mshue's Avatar
either fast idle valve or cable is stuck open
Old Nov 15, 2007 | 12:09 AM
kalel's Avatar
nothing is wrong with the cable, cable is just fine.
H23Lude9
Aug 6, 2008 07:52 AM
Bad4life2000
Jan 17, 2008 09:42 AM
LastMinuteRacin
Dec 31, 2005 12:34 AM
tegman96
Oct 18, 2004 07:04 AM
The real Ryan
Apr 23, 2003 04:11 PM
