need help wont go above 3500
Old Jun 23, 2008 | 06:03 AM
  #21
kf91da9's Avatar
D15b1>k20a
kf91da9 has disabled reputation
Default Re: need help wont go above 3500
Originally Posted by novtec
ive had this happen b4. i believe its the crank angle sensor. change your dizzy
Originally Posted by 1rude2l
Try another dizzy, more than likely your problem.
its the dizzy i had exactly the same problem
Old Jun 23, 2008 | 06:05 AM
  #22
sloazzep3's Avatar
snatchback scootin
sloazzep3 sloazzep3 sloazzep3 sloazzep3 sloazzep3 sloazzep3 sloazzep3 sloazzep3 sloazzep3 sloazzep3 sloazzep3
tried already no go
Old Jun 24, 2008 | 12:44 PM
  #23
sloazzep3's Avatar
snatchback scootin
any other suggestions
Old Jun 24, 2008 | 12:56 PM
  #24
banned_user's Avatar
banned_user is an unknown quantity at this point
our hondas use fuel to cool the intank fpump, so if youre always damn near empty, that shit will fail in summers, also, theres a fuckin ground wire that commonly causes this...I JUST CANT REMEMBER WHICH FUCKING ONE. EXACT SAME THING happened to me last summer.
Old Jun 24, 2008 | 02:01 PM
  #25
spnamnt's Avatar
CIMSPORT
spnamnt has disabled reputation
first off, you say you have an LS but are using a chipped b16 ecu? you need a 90-91 pr4 ecu from an integra, this sounds like a wiring issue, where are you locateD?
Old Jun 25, 2008 | 09:41 AM
  #26
sloazzep3's Avatar
snatchback scootin
i dunno what it is man im stumped.....someone come help me ill pay
Old Jun 25, 2008 | 11:10 AM
  #27
lamarc's Avatar
registered user
lamarc has disabled reputation
cheeck all fluids and you got new plugs wires timming grounds pritty much eletrical is most liky somethingt to do with it
Old Jun 25, 2008 | 11:24 AM
  #28
Originally Posted by sloazzep3
yea got a spare one im goin to check out....
im going to try another ecu as well....it has a chipped b16 ecu with no rev limiter on it...so i dunno
If that ECU is still setup for a B16, you're probably getting knock sensor faults, and VTEC faults (unless the program was specifically made for that engine and has that stuff disabled). Try the correct ECU for that engine, and then see where you are. You're trying to work on too many variables at once right now; get as simple of a setup as you can, and if that works fine then start adding variables back in until you find which one is causing it. Then you can fix it. You're taking a shotgun approach right now it sounds..
Old Jun 25, 2008 | 11:28 AM
  #29
need to take it to the shop to hook it up to see which codes.
You can't really do that with an OBD0 or OBD1 ECU. THere is a little clear window on the top cover of the ECU case, and the codes will flash the LED that you can see through there. If you're getting a CEL, you have a good starting point to figure out what's wrong. Chances are good it's a wiring issue with the ECU though, there are some differences from model to model if I remember correctly, so there is a chance you don't have the right pinout for that ECU. Someone with more OBD0 knowledge should verify that; I'm just going out of my shaky memory.
Follow instructions for CEL lookup here:
http://crxcommunity.com/viewtopic.php?t=9903
Woodpsuher50mm
Apr 25, 2008 05:50 AM
rotaryking
Aug 17, 2006 04:39 PM
White Pinoy
Apr 15, 2006 08:03 AM
greekfreak
Mar 29, 2006 01:34 PM
