need help! fuses keep blowing
Old Jun 25, 2008 | 10:12 AM
egcoupejdm's Avatar
egcoupejdm has disabled reputation
Default need help! fuses keep blowing
Well for some reason my tail light/cluster/licence plate fuse and my alarm fuses keep blowing out on my eg. Ive bought new ones and when i turn my lights on they just burn out, and for the alarm fuses when i try to arm my alarm, the fuse thats for the cornor lights burns out. I hope someone can help me out becuase I really dont want to get pulled over when im driving at night.thanks!
Old Jun 25, 2008 | 10:25 AM
boyband's Avatar
UNCEUNCEUNCEUNCEUNCE
boyband boyband boyband boyband boyband boyband boyband boyband boyband boyband boyband
Default Re: need help! fuses keep blowing
Sounds to me like something is grounding out somewhere, thus blowing the fuses. Make sure that everything is either wire nutted or electrical taped up properly and isn't touching any metal.
Old Jun 25, 2008 | 10:30 AM
egcoupejdm's Avatar
thanks im gonna check right now.
Old Jun 25, 2008 | 11:20 AM
egcoupejdm's Avatar
made sure everything was ok...and i still dont know what the problem is..
Old Jun 25, 2008 | 11:31 AM
buugiewuugie's Avatar
Zombies found Waldo
sounds like a ground in the stereo. Did you pull out the stereo and check those wires?
boyband's Avatar
Something is either grounding or not grounded out properly or you might even have some wires crossed somewhere.
Same thing happened to me when I wired up my stereo. I accidentally, while using a stereo wiring harness, wired it up to the wrong wire. It was supposed to be orange/orange, but I put the wire to orange/white. The minute I turned my lights on, I blew everything in the cluster and fried a trace. I ended up having to get a new cluster because of that because it couldn't be jumped.
Old Jun 25, 2008 | 11:39 AM
aacjohnc's Avatar
if you have a aftermarket alarm that will happen to if not hook up correctly cause the alarm is ran through your lights and cluster as well . try unhooking the brain for the alarm and try it and see if you still blow fuses seen this happen plenty of times on bad installs..
could be a bad relay as well check those ?
D1NONLYJV43
May 21, 2008 07:54 AM
GOOKY4U
Apr 29, 2008 01:37 PM
slolikeu
Mar 12, 2006 06:23 PM
junior1643
Apr 17, 2005 12:44 PM
NIC668
May 26, 2003 09:01 AM
