need help wont go above 3500
Old Jun 19, 2008 | 06:31 PM
team703's Avatar
Default Re: need help wont go above 3500
Def. Limp mode. Check what code is being thrown. My friend had a gsr swapped 91 hatch and that bitch wouldn't rev past 3500, It would just bounce as if it was 2 stepping. Checking all wiring and double check to see if the wires at the ecu are correct.
http://hondaswap.com/swap-articles/d...writeup-49557/ <read that as your checking your harness etc
Old Jun 19, 2008 | 07:05 PM
banned_user's Avatar
banned_user is an unknown quantity at this point
when mine did it i couldnt get past 3200ish. It's a learning opportunity that places alot of stress on the transmission.
Old Jun 20, 2008 | 05:35 AM
sloazzep3's Avatar
snatchback scootin
sloazzep3 sloazzep3 sloazzep3 sloazzep3 sloazzep3 sloazzep3 sloazzep3 sloazzep3 sloazzep3 sloazzep3 sloazzep3
thanks for all input, i will be checking all this over the weekend.. dont have much time to work on it during the week......and if i cant figure it out i will just take it to our local honda specialst and pay out the ass
Old Jun 20, 2008 | 12:43 PM
1rude2l's Avatar
Try another dizzy, more than likely your problem.
Old Jun 20, 2008 | 12:56 PM
sloazzep3's Avatar
snatchback scootin
yea got a spare one im goin to check out....
im going to try another ecu as well....it has a chipped b16 ecu with no rev limiter on it...so i dunno
Old Jun 20, 2008 | 12:59 PM
SPAWN's Avatar
I <3 My DSM
SPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud of
make sure cuz it sounds to me like the ecu might be in "safety" mode(or whatever its called), which if so , doesnt go above 3500 rpms
Old Jun 21, 2008 | 09:49 PM
could also be fuel pump, on a hot day does it ever sputter then die....for a while?
Old Jun 21, 2008 | 09:54 PM
jfish360's Avatar
Love to Crx
jfish360 is an unknown quantity at this point
Its limp mode, omg!!!!! You dont have any cells you say? If so swap ecus, because this "chipped ecu" might be your problem.
Old Jun 23, 2008 | 04:34 AM
sloazzep3's Avatar
snatchback scootin
ok so its in safe mode..... didnt have a chance to hook up different ecu...its not the chipped b16 one i was told was in there its a pr4. cel is on....need to take it to the shop to hook it up to see which codes........
i tried everything else....different dizzy, different sensors...just basically spent most of my weekend being pissed off about it
Old Jun 23, 2008 | 04:56 AM
crxrookie's Avatar
look what you did!
crxrookie crxrookie crxrookie crxrookie crxrookie crxrookie crxrookie crxrookie crxrookie crxrookie crxrookie
Originally Posted by sloazzep3
just put new plugs and wires
Check the sevice manual for the firing order , make sure you have the plug wires in the right order. I've had this happen to me b4 , I belive mine was a vacume line , I can't remember but I know I was something really dumb. Could be something like a loose wire connector.
