Massive engine problems. please help
Old Feb 19, 2008 | 10:24 AM
  #21
zappas's Avatar
been around awhile.
zappas zappas zappas zappas zappas zappas zappas zappas zappas zappas zappas
Default Re: Massive engine problems. please help
Yea, you sure do.
Old Feb 19, 2008 | 10:31 AM
  #22
B18A1 CRX's Avatar
98 gsr civic
B18A1 CRX has disabled reputation
yea i kno. thank you. any suggestions
Old Feb 19, 2008 | 04:19 PM
  #23
B18A1 CRX's Avatar
98 gsr civic
Old Feb 19, 2008 | 07:29 PM
  #24
B18A1 CRX's Avatar
98 gsr civic
Old Feb 20, 2008 | 07:02 AM
  #25
B18A1 CRX's Avatar
98 gsr civic
morning bump
Old Feb 20, 2008 | 12:07 PM
  #26
Sandfrog's Avatar
Sandfrog has disabled reputation
Originally Posted by B18A1 CRX
any suggestions
Buy a FSM
Old Feb 20, 2008 | 12:16 PM
  #27
BillMW's Avatar
go topless.
BillMW has disabled reputation
I had a similar problem but there was more smoke than oil; it turned out to be a blown/cracked valve. Something like this:
Hope this helps. Good luck with your diagnosis.
Old Feb 20, 2008 | 12:36 PM
  #28
RandomTask's Avatar
I’m gonna go with a valve guide. This would explain the noise and the oil getting into the combustion chamber. Also, plugs can foul when they get enough oil on them. Do a compression and leak down test on that cylinder and let us know what you find. Other than that, you’re gonna have to pull the head and investigate further.
Old Feb 20, 2008 | 01:39 PM
  #29
Scotty_Nooo's Avatar
A.K.A Jebus
Originally Posted by Sandfrog
head gasket blown
if it was the head gasket there would be antifreeze in the oil or oil in the anti-freeze, sounds like a rod knock, but you valve seat could have gone bad which would account for the knocking sound and burning of oil
Old Feb 20, 2008 | 03:41 PM
  #30
B18A1 CRX's Avatar
98 gsr civic
headin out right now to puill the head out. thanks for the pic. will repost with results
tpage0007
Jul 24, 2008 10:21 PM
Qu33F
Nov 5, 2003 06:26 PM
Carter
May 22, 2003 07:07 PM
