engine swap problems
Old Jul 23, 2008 | 07:46 AM
tpage0007's Avatar
tpage0007 has disabled reputation
Default engine swap problems
i have a 91 civic hb nonvtec it had a d15b1 engine in it at first and i replaced it wit a d16a6 engine from what i have heard its a direct swap. i left the motor mpfi and used my intake manifold from the d15 motor should i have used the intake manifold from the d16a6 instead. no codes come up the car starts up runs perfect then dies down as if its not gettin any fuel. i checked the timing, spark plugs, firing order, everything is good. no check engine light is on. need some help
Old Jul 23, 2008 | 07:53 AM
BentValve's Avatar
Sorry. Not really.
BentValve BentValve BentValve BentValve BentValve BentValve BentValve BentValve BentValve BentValve BentValve
Default Re: engine swap problems
I think I know the problem. Would you like to discuss it over dinner?
Old Jul 23, 2008 | 07:58 AM
Speed-O's Avatar
smuggling grapes
Speed-O Speed-O Speed-O Speed-O Speed-O Speed-O Speed-O Speed-O Speed-O Speed-O Speed-O
lol.
sounds like you have a fuel problem...
Old Jul 23, 2008 | 08:04 AM
BentValve's Avatar
Sorry. Not really.
so it starts, runs for a few seconds and dies? What ecu are you using?
Old Jul 23, 2008 | 09:23 AM
tpage0007's Avatar
I am using the original ecu that came in the car.
Old Jul 23, 2008 | 09:52 AM
kwint's Avatar
kwint has disabled reputation
You need to find a PM6 ecu I believe. Hook that up, and it should fire right up.
Old Jul 23, 2008 | 09:59 AM
tpage0007's Avatar
thanx man. ima try dat.
Old Jul 23, 2008 | 10:11 AM
type.r_eghatch's Avatar
type.r_eghatch has disabled reputation
Got tha PM6 if you need it.
Old Jul 23, 2008 | 10:12 AM
El Oh El
Old Jul 23, 2008 | 10:22 AM
Quangalang's Avatar
Quangalang Quangalang Quangalang Quangalang Quangalang Quangalang Quangalang Quangalang Quangalang Quangalang Quangalang
A PM6 ECU will not work well with a DPFI intake manifold.
