Intercooler Sprayers Home made???
Old Jan 24, 2004 | 02:51 PM
  #51
axis45's Avatar
axis45 has disabled reputation
i just use washer fluid, its like %50 methonal. i installed water/methonal injection on my car, identical to the "boost cooler" system and was very impressed, i could advance my timing about 8 degrees from its retarded below stock setting, lean out my hi throttle settings on my afc, and i saw a huge power gain. people say you shouldnt use washer fluid because of the soap additive deposits in the intake but i have been using it for a while and i havent seen and bad effects from it. the car runs better in general since i started using it, i guess because of the carbon cleaning propertys of steam. i have an injection setup just like mine that is missing a part, but as soon as i get that part it will be for sale on drag
Old Jan 24, 2004 | 07:49 PM
  #52
ToyotaTechGeek's Avatar
brake/steer/throttle
you've obviously confused external intercooling for internal intercooling.
Old Jan 25, 2004 | 07:33 AM
  #53
Jason300zxTT's Avatar
Jason300zxTT Jason300zxTT Jason300zxTT Jason300zxTT Jason300zxTT Jason300zxTT Jason300zxTT Jason300zxTT Jason300zxTT Jason300zxTT Jason300zxTT
Another thing i dont get... is how the hell do you spray water mist into a air intake... i thought if water got in the motor it would "hydro-lock" so new question... how is that possible with out f'in up ur motor?
Old Jan 25, 2004 | 08:36 AM
  #54
Boosted2003's Avatar
you use a injector. It mists it into the tubing..
Old Jan 25, 2004 | 10:04 AM
  #55
mpg9999's Avatar
mpg9999 is an unknown quantity at this point
How is this possible without messing up the motor? Easy, your not injecting enough to hydrolock it. Why doesnt the fuel you inject hydrolock the motor? There isnt enough.
-Mike
Old Jan 25, 2004 | 02:53 PM
  #56
the idea behind water injection is atomized water droplets, not a freakin water fountain. water hydrolocks and engine 'cause you can't compress water.
Old Jan 25, 2004 | 09:27 PM
  #57
SLO-4G63's Avatar
Douchebaggery!!!
SLO-4G63 SLO-4G63 SLO-4G63 SLO-4G63 SLO-4G63 SLO-4G63 SLO-4G63 SLO-4G63 SLO-4G63 SLO-4G63 SLO-4G63
Just get a NX Ntercooler kit....might set you back a little change but they boast a 50+hp gain....
TRU
Other ARCHIVE
Jan 22, 2008 07:35 PM
cleanEK
Nov 23, 2007 05:04 AM
H22blkaccord20
Sep 21, 2006 03:34 AM
Wii
Jan 8, 2005 03:27 PM
SLEEPERFORD
Jul 29, 2003 12:11 PM
