home made mount?
Old Nov 20, 2007 | 09:11 PM
cleanEK's Avatar
Default home made mount?
how reliable is filling a motor mount with m3 window weld?
Pros / cons?
Old Nov 21, 2007 | 06:44 AM
CavemanRacing's Avatar
www.CM-R.net
CavemanRacing CavemanRacing CavemanRacing CavemanRacing CavemanRacing CavemanRacing CavemanRacing CavemanRacing CavemanRacing
Default Re: home made mount?
It works. I have been using a polyurethane epoxy in my mounts. Thinking about selling the stock filled mounts soon if you are interested.
Old Nov 21, 2007 | 06:45 AM
streetlamp's Avatar
MAGICAL FRIENDSHIP
streetlamp streetlamp streetlamp streetlamp streetlamp streetlamp streetlamp streetlamp streetlamp streetlamp streetlamp
Pros / cons?
Pros-
Your motor wont be bouncing all over the place
Your lady friends will get a nice vibration
Old Nov 21, 2007 | 07:11 AM
Originally Posted by driveahonda
It works. I have been using a polyurethane in my mounts. Thinking about selling the stock filled mounts soon if you are interested.
Fixed it for you. Polyurethane epoxy doesn't exist, except in some hybrid coating systems.
See the other recent post on this topic for my full opinion on Window Weld.
Old Nov 21, 2007 | 10:37 AM
www.CM-R.net
lol... If you weren't an automotive genius I would try to argue that comment. In the mean time, I will accept your word as fact and question the source that is getting me this so called "polyurethane epoxy".
Old Nov 21, 2007 | 11:37 AM
What brand and where does it come from? There is epoxy, and there is polyurethane, but polyurethane epoxy (epoxy modified with polyurethane) is some pretty whizzbang polymer chemistry, and pretty new/rare right now. Whoever you're getting it from is probably calling it epoxy because it's two parts that are mixed together instead of just one single part(like the Window Weld).
Old Nov 21, 2007 | 11:41 AM
www.CM-R.net
Will check later. It is used in polyurethane flooring though.
Old Nov 21, 2007 | 12:08 PM
Oh.. it probably is poly epoxy then, floor coating is one of the only applications I know of at the moment. That was the hybrid coating system I was talking about.
That should be significantly harder durometer then you would want to fill a motor mount with though..?
Are you getting it from IFPC in Norfolk?
Old Nov 21, 2007 | 04:49 PM
TurboEG8's Avatar
...pulls trailer!!!
TurboEG8 TurboEG8 TurboEG8 TurboEG8
yes it's well worth the time, my timing mount is filled and up until I took off my dampener, it was working fine. Then I had people driving my car to and from the track that didn't know how to drive 5 speed and the mount went to shit.
Old Nov 21, 2007 | 05:10 PM
The trick is to cut most of the stock rubber out first; the stock rubber will destroy itself quickly if you don't. You'll find the weak link very fast with that much force and nothing compliant enough to damp it.
