idle problem
Old Mar 17, 2004 | 06:51 PM
Zen's Avatar
Zen
Zen Zen Zen Zen Zen Zen Zen Zen Zen Zen Zen
Default idle problem
i have a 94 sol si and whenever i start up the car it always idles rough...it goes up and down from 1000 to 2000 rpms then back down quickly...it's nothing major..just annoys the hell outta me...after a few minutes it dies back out and returns to normal...let me know if you have any solutions to my problems...thanks in advance..
Old Mar 17, 2004 | 06:57 PM
LightY3arZ's Avatar
LightY3arZ is an unknown quantity at this point
Default Re: idle problem
Have you checked your Idle Air Control valve?
Old Mar 17, 2004 | 07:01 PM
Zen's Avatar
Zen
yup..checked the iac valve..it's clean
Old Mar 17, 2004 | 07:05 PM
DomesticDesire's Avatar
always broke
DomesticDesire is a splendid one to beholdDomesticDesire is a splendid one to beholdDomesticDesire is a splendid one to beholdDomesticDesire is a splendid one to beholdDomesticDesire is a splendid one to beholdDomesticDesire is a splendid one to beholdDomesticDesire is a splendid one to beholdDomesticDesire is a splendid one to behold
this may sound stupid, but did you check your coolant level?
if it isnt that, it may be your TPS.
Old Mar 17, 2004 | 07:13 PM
GotB00stPsi's Avatar
GotB00stPsi is an unknown quantity at this point
bleh replace your iac, its fried, set your timing, and adjust your throttle cable, or is there a screw to adjust the air like on a dsm? there was a lil screw you could mess with, that and adjusting my cable tigher fixed my problem
Old Mar 17, 2004 | 08:29 PM
Saint_James's Avatar
ungezogen mench
Saint_James is an unknown quantity at this point
Sounds like a vacuum leak. I have the same on mine, I just know what it is and i haven't gotten around to fixing it yet. I'd check all of your lines, it's the cheap and easy way to possibly fix it.
Old Mar 27, 2004 | 12:46 PM
If it's not IACV, it's usually vac leak, I agree..
Old Mar 27, 2004 | 06:06 PM
Not_Blazin's Avatar
Not_Blazin is an unknown quantity at this point
Mine was like that... it was a vacuum leak.
Old Mar 27, 2004 | 07:42 PM
spooledex's Avatar
spooledex spooledex spooledex spooledex spooledex spooledex spooledex spooledex spooledex spooledex spooledex
take off your intake and you will see 2 holes inside. when it does it, put your finger over each hole one at a time. don't let it suck your finger in. but if it's the top hole that stops it then it's the aic or whatever it's called on the back. If it's the bottom hole check your fluid level and make sure the automatic choke thingy is screwed in all the way. it's the thing on the bottom of your throttle body where coolant goes in. You can bypass it too.
H23Lude9
Aug 6, 2008 07:52 AM
Bad4life2000
Jan 17, 2008 09:42 AM
LastMinuteRacin
Dec 31, 2005 12:34 AM
tegman96
Oct 18, 2004 07:04 AM
The real Ryan
Apr 23, 2003 04:11 PM
