Engine question
Old Apr 7, 2005 | 07:05 PM
Visualimpact757's Avatar
Hardly working
Visualimpact757 Visualimpact757 Visualimpact757 Visualimpact757 Visualimpact757 Visualimpact757 Visualimpact757 Visualimpact757 Visualimpact757 Visualimpact757 Visualimpact757
Default Engine question
I have a b16 engine and it is missing the knock sensor. Is this actually needed for Vtec. Ive heard that it is and that it isnt. DO i need this to actually run my motor?
Old Apr 7, 2005 | 07:31 PM
SlowLS's Avatar
Sumospeed #O.G.
Default Re: Engine question
No. just ground out the wire for the knock sensor coming from the ecu to the body of the car. If your motor is knocking, you will know cause it is blown. If you need one, I'm pretty sure I have one.
Old Apr 7, 2005 | 07:46 PM
Hardly working
Well i was told if i didnt connect it, it would code so i really didnt want that to happen. But yea if so how much would u want for the sensor? u jave the plug that plugs into it as well?
Old Apr 8, 2005 | 06:03 PM
Abysalone's Avatar
Fighterer
Abysalone will become famous soon enough
Do you even know what a knock sensor does? I dont know about hondas but I dont know why the hell you would pull that. It detects detonation and retards timing to keep your car from blowing up.
Old Apr 8, 2005 | 06:42 PM
It's not really needed if your setup (ECU and engine) is tuned properly.. Many people don't use them, and don't have a problem. You can go without a knock sensor if your ECU is chipped, the knock sensor output just has to be disabled in the program (chip).
Old Apr 8, 2005 | 08:25 PM
Abysalone's Avatar
Fighterer
Ahh I see. IMO its better to leave it in and tune the car so it doesnt see detonation. Then if you ever do see it, your motor may be saved. Wasnt trying to sound like a dick there, like I said I dont know much about hondas.
Old Apr 8, 2005 | 10:45 PM
PRO-Habit's Avatar
I'M BACK
PRO-Habit
do the 92-95 jdm b16's running a p30 ecu need a knock sensor? Mine isnt hooked up and yet it has never thrown a code for it.....my car runs fine
Old Apr 9, 2005 | 08:12 AM
Strange, you should be throwing a code... JDM ECUs are funny about some stuff though, the USDM ECUs will throw a code if you sneeze.
BLU CIVIC
Jan 27, 2009 01:33 PM
gsr-turd
Nov 3, 2007 04:48 PM
Sgnos
Apr 8, 2005 09:40 AM
Von
Apr 10, 2004 04:01 AM
El Negro
Aug 18, 2003 03:45 AM
