engine question
Old Nov 3, 2007 | 06:15 AM
gsr-turd's Avatar
h22 POWA
gsr-turd gsr-turd gsr-turd gsr-turd gsr-turd gsr-turd gsr-turd gsr-turd gsr-turd gsr-turd gsr-turd
Default engine question
ok i have a question i been trying to look it up but can't find alot about it.
is a stock gsr faster than doing a b16 with a gsr head? i thought about pulling my gsr and doing it or just pulling the head off my car and putting a spoon head gasket on that is suppose to help increase the compression alittle...
Old Nov 3, 2007 | 06:33 AM
MORE IMPATIENT's Avatar
DESTROYS DONUTS !!
Default Re: engine question
why would you want to decrease displacement and torque by replacing your 1.8 with a 1.6, mod your gsr, do the headgasket if your wanting to raise compression a bit, granted youll only get like .2 raise in ratio and you really wont gain any power from it. if you work the gsr head, mill it,get a better intake manifold and some bigger cams and tune it, your gsr will be great. hell you could always swap the pistons out when you do the headgasket and put some high compression jammies in there.
high compression pistons, thin headgasket, mild port and polish, cams and intake manifold, lightweight flywheel and some tuning- FUN ASS MOTOR.
Old Nov 3, 2007 | 06:35 AM
gsr-turd's Avatar
h22 POWA
ya i was only asking cause my friend got a b16 block completely rebuilt with 0 miles and i can get it for a steal thats only reason i was just trying to see if it make around same power cause i just want a 0 mile motor
Old Nov 3, 2007 | 06:43 AM
DESTROYS DONUTS !!
well hell if you can get it for cheap than get it. if anything i would get it, work the b16 head than put it on your gsr.
Old Nov 3, 2007 | 07:15 AM
gsr-turd's Avatar
h22 POWA
its only the b16 block no head or nothing i was just trying to see if it be any kinda gain
Old Nov 3, 2007 | 04:48 PM
shrekplaya's Avatar
shrekplaya is an unknown quantity at this point
put the b16 pistons in the gsr block and get a b16 head
BLU CIVIC
Jan 27, 2009 01:33 PM
Visualimpact757
Apr 9, 2005 08:12 AM
Sgnos
Apr 8, 2005 09:40 AM
Von
Apr 10, 2004 04:01 AM
El Negro
Aug 18, 2003 03:45 AM
