DA idleing problem
Old Apr 1, 2007 | 05:36 PM
SlowLS's Avatar
Sumospeed #O.G.
Default Re: DA idleing problem
Originally Posted by 87 mini s10
OK its more than likely airpockets, a leak, or not enough coolant in your coolant system. You should pressure test ur coolant system if its not holding pressure it wont open the IAC(idle air control) valve and it will idle like that i went through this and make sure ur idle is set right
No it is more than likely not.
Old Apr 1, 2007 | 06:42 PM
CHAHONDA's Avatar
corona connessuer
Originally Posted by SlowLS
TPS does not cause a bouncy idle It is most likely the FITV.
i strongly agree......fitv.....fix it....problem solved!
nogo1231
Aug 29, 2007 07:27 AM
sive ick
Jan 19, 2007 01:38 PM
Slepping_H22_DC
Dec 31, 2006 07:19 PM
