DA idleing problem
Old Mar 31, 2007 | 08:12 AM
Slick9898's Avatar
Slick9898 is infamous around these partsSlick9898 is infamous around these partsSlick9898 is infamous around these partsSlick9898 is infamous around these partsSlick9898 is infamous around these partsSlick9898 is infamous around these partsSlick9898 is infamous around these partsSlick9898 is infamous around these partsSlick9898 is infamous around these partsSlick9898 is infamous around these partsSlick9898 is infamous around these parts
Default DA idleing problem
when im driving it its fine but when i throw it in neutral comin up to a stoplight or something it revs up and down from 2k back down to 1 anyone know whats causing this?
Old Mar 31, 2007 | 09:22 AM
Don_is_Rad's Avatar
ooooooooooowwweeeeee
Don_is_Rad has disabled reputation
Default Re: DA idleing problem
air intake temp sensor??
Old Mar 31, 2007 | 04:25 PM
SlowLS's Avatar
Sumospeed #O.G.
FITV. Just search through tech talk for the 1 million posts about idle problems. Or for $20 I will come to you and fix it.
Old Apr 1, 2007 | 07:01 AM
hanlonr9's Avatar
hanlonr9 has disabled reputation
thats either a throttle position sensor or a Idle air control valve the intake air temprature dont got nothing to do with that
Old Apr 1, 2007 | 07:05 AM
kalel's Avatar
Ground Level Imports
kalel has disabled reputation
its your TPS sensor, the sensor monitors what location the throttle is in and if that sensor goes out or is just missing or not hooked up the ecu doesnt know how to compensate the injectors for the throttle change so it just causes the idle to go up and down. when you take off it will be fine or at least seem like it when actuality you are burning alot more fuel than you think and which will actually cause you to lose horsepower. ever notice how your tank seems to empty alot faster?
Old Apr 1, 2007 | 07:21 AM
SlowLS's Avatar
Sumospeed #O.G.
TPS does not cause a bouncy idle It is most likely the FITV.
Old Apr 1, 2007 | 08:13 AM
vietballer's Avatar
vietballer vietballer vietballer vietballer vietballer vietballer vietballer vietballer vietballer vietballer vietballer
i would say IAC
Old Apr 1, 2007 | 12:53 PM
greekfreak's Avatar
HollyLeuia HollaBack
greekfreak greekfreak
FITV ! thats the problem I had with my h23. but It wouldnt hurt to clean out your IAC valve either
http://www.g2ic.com/forums/showthrea...threadid=44386
theres the write up for the FITV
Old Apr 1, 2007 | 03:03 PM
SlowLS's Avatar
Sumospeed #O.G.
I've also posted the link to how to fix your fitv in about 10 other idle problem threads.
Old Apr 1, 2007 | 04:28 PM
diggity dave's Avatar
VTEC
diggity dave is on a distinguished road
OK its more than likely airpockets, a leak, or not enough coolant in your coolant system. You should pressure test ur coolant system if its not holding pressure it wont open the IAC(idle air control) valve and it will idle like that i went through this and make sure ur idle is set right
