Need help please, i have a weird problem with my car.(thanx in advance) Ghost problem
Old 02-02-2004, 12:59 PM
TheMx3's Avatar
TheMx3 is an unknown quantity at this point
Default Need help please, i have a weird problem with my car.(thanx in advance) Ghost problem
Ok here goes. my car likes the just shut off when ever it feels like it out of nowhere. I haveing troubles depicted a pattern. it just seems to do it when ever, and when it does shut off my radio stays on and so does my dash panel.(thats about all i know)
Here are things i have fixed/changed(i have two mx3's one is junked for parts)
disty (ing module is in the disty as far as i know , same with coil)
throttleplate
tps
iac
checked all vac hoses
check wire harnesses to best of my abitly
cps
ecu
vaf
fuelrails
fuel pump
fuel filter
ing switch
fpr
the solnoid that connects the the fpr via vac hose
checked for leaks useing carb spray
hmm i might be forgetting some but thats all i remember for now.
ok the only new thing i found out about the problem is this.... after the car shuts of and im still rolling in gear, if i choose to downshift(and i often do to start the car back up while other tims i jjust start it up with the key) anyway when i down shift i still have loud exhaust sound. Now if the cars engine is shut down..dont ya think there should be no exhaust sounds(exhaust sound = combustion chamber is still working...right?) so whatya think about that? andmy car is super loud so theres not mistaken it.
recap
rpms read 0
push gas nohting happens
yet i still here nice old exhaust sounds when i down shift
....start it back up it runs fine
also it ran fine for about a hour..then i shut her iff for 20 mins...ran her again and shit died in 10 mins or less
if u can help , please do .
im at a lose here.
sorry for all the writeing.
TheMx3 is offline
Old 02-02-2004, 04:10 PM
TheMx3's Avatar
Default Re: Need help please, i have a weird problem with my car.(thanx in advance) Ghost problem
well i just realized why the exhaust is still sounding....the tranny was still turning the engine...duh.
TheMx3 is offline
Old 02-02-2004, 04:52 PM
i like prom.
urvtecs2slo's Avatar
you stalled.
urvtecs2slo is offline
Old 02-02-2004, 05:02 PM
Dick's Avatar
Dick has disabled reputation
check engine and ecm grounds is ck engine light on check for cods
Dick is offline
Old 02-02-2004, 05:14 PM
TheMx3's Avatar
no unlike some people i know how to drive stick anyway yeah no codes already scantooled it..no check light either. and i check all the grounds i could find . sorry forgot to mention those. thanx for the replys.
TheMx3 is offline
Old 02-02-2004, 05:18 PM
Dick's Avatar
try cleaning the maf sensor with brake clean
Dick is offline
Old 02-02-2004, 05:44 PM
NIC668's Avatar
umm no
that would not be smart! you will fry the sensor. Try replacing that sensor with one from the parts car. ALSO just because you changed parts does not mean the part you put on the car is not bad also.
Good Luck on finding the problem
NIC668 is offline
Old 02-02-2004, 06:50 PM
TheMx3's Avatar
yeah i k know..i just know my old casr ran perfect before it got reaeended...so im just assuming the parts work. yeah i dont have a maf..i have vaf..(vane airfllow) basically same thing..just gayer. switched that to.. yeah i need some luck. thanx guys.
TheMx3 is offline
Old 02-02-2004, 07:34 PM
evolutioned_RX7's Avatar
evolutioned_RX7 is an unknown quantity at this point
did you try swapping the ecu?
evolutioned_RX7 is offline
Old 02-02-2004, 08:09 PM
Blow Me
Stillpushin's Avatar
Stillpushin is an unknown quantity at this point
Sounds to me like a problem with the distributor. I know you said you replaced it but like mentioned before it can still be bad.
Stillpushin is offline
Quick Reply: Need help please, i have a weird problem with my car.(thanx in advance) Ghost problem
