car shakes when i hit the brakes
Old Oct 22, 2009 | 04:47 PM
1camslw's Avatar
Special-k
1camslw 1camslw 1camslw 1camslw 1camslw 1camslw 1camslw 1camslw 1camslw 1camslw 1camslw
Default Re: car shakes when i hit the brakes
sounds like rotors...but it also mite b a wheel bearing....i had a lincolin that did that every time i hit the brakes the car would shake and the steering wheel would to....i fixed both the rotors and wheel bearings and it went away.
Old Oct 22, 2009 | 06:04 PM
ShawnD's Avatar
Troll & Run
Fixing two things at once doesn't help at all.
Old Oct 22, 2009 | 06:18 PM
1camslw's Avatar
Special-k
it did 4 me....
Old Oct 22, 2009 | 06:22 PM
NasTHatch's Avatar
RIP DRAGVA-2016
step one: raise your car back up
step two: get new rotors
step 3: get an alignment and dirve your car like a normal car and it will last a long time because you won't be encouraged to drive like a dumb shit knowing you have a stock car.
Old Oct 22, 2009 | 07:10 PM
idriveahonda's Avatar
Shooting 63's
I had the same problem.
I was missing two lugnuts...and another was loose...
You never know...
Old Oct 22, 2009 | 07:17 PM
spruill745's Avatar
doin it big
spruill745 has disabled reputation
^ are you kidding?
warped rotors, dealt with this more than once. check your fluid and pads too.
Old Nov 7, 2009 | 04:39 PM
ridinboost757's Avatar
I <3 757
ridinboost757 is a name known to allridinboost757 is a name known to allridinboost757 is a name known to allridinboost757 is a name known to allridinboost757 is a name known to allridinboost757 is a name known to all
check all suspension components in the front. jack the vehicle up and grab the tire from both sides then shake and see if there is any independent movement anywhere. do the same thing with the top and bottom of the wheel. Also alot more stress is added to the wheelbearings on a lowered car, so i'd check that out. Lastly mabey a stuck caliper? Idk just my 2 cents.
Scottyk6
Oct 30, 2007 08:57 PM
WontPassMe
Sep 10, 2007 08:03 PM
ultra spikey
Aug 3, 2006 04:03 PM
ultra spikey
Apr 22, 2006 05:41 AM
Sleeper88Civic
May 28, 2003 06:40 PM
