99 interga cranks but will not start
the other day my interga started then cut off now it cranks but no strt it is getting fuel. Could it be the ingition coil any help please no stupid post only helpful information
its just a website
Re: 99 interga cranks but will not start
have you fucked with it at all?
cheap mans swap? crossed hoses? wiring problem? give more info
the firing order could be fucked up too, either in the plugs or cap
give more info im sure someone can help
no the motor is the stock gsr with few bolt on no plug wire have been messed with at all the only thing im thinking is maybe the coil but want some ideas before i go taking shit apart that is working fine
its just a website
a faulty coil can give the plugs enough current to turn over but wont keep the car running
or it can cause the car not to ignite at all
test it with multimeter to avoid wasting money
Go cry to momma
Take a plug wire off, stick a known-good spark plug in the boot and hold it to the valve cover nut or something that's grounded. Crank it over, check for spark.
You Sir.. in my opinion should prepare for the worst and hope for the best thats my moto.... Sounds as if to me that you broke the timing belt and im pretty sure you've bent a valve or two... Take valve cover off try n bump it n see if the tiing gears up top move or befor you even do that see if it has tension... Pretty sure its a gonner tho....
