Car will not start/turn
Old 12-22-2007, 08:59 PM
Full-time New Guy
Scottyk6's Avatar
Scottyk6 has much to be proud ofScottyk6 has much to be proud ofScottyk6 has much to be proud ofScottyk6 has much to be proud ofScottyk6 has much to be proud ofScottyk6 has much to be proud ofScottyk6 has much to be proud ofScottyk6 has much to be proud ofScottyk6 has much to be proud ofScottyk6 has much to be proud ofScottyk6 has much to be proud of
Default Car will not start/turn
Just bought a used 95 Civic with an LS swap. Parked it in the garage today, and when I went to start it again, nothing happened. When I turn the key, there's a very low whining/straining noise, and nothing else happens. No spark or anything. Any idea what could have gone wrong? I didn't mess with any engine components.
Scottyk6 is offline
Old 12-23-2007, 06:09 AM
1rude2l's Avatar
Default Re: Car will not start/turn
battery dead?
1rude2l is offline
Old 12-23-2007, 07:28 AM
QUICKVIII's Avatar
QUICKVIII has disabled reputation
Dead battery, bad battery connections, one or more blown main fuses, Bad ground, etc...
QUICKVIII is offline
Old 12-23-2007, 07:37 AM
Full-time New Guy
Scottyk6's Avatar
Originally Posted by 1rude2l
battery dead?
Electronics work fine. Cluster lights and headlights turn on. I'll check the fuses for the hell of it, and the grounds also.
Scottyk6 is offline
Old 12-23-2007, 07:43 AM
QUICKVIII's Avatar
Bad ground at engine, wire off of the starter solenoid, bad main fuse in fuse box under hood, bad ignition switch, I can go on and on. Get a volt meter and find where the circut is bad. jump from battery to solenoid (under hood) to see if starter works. ??? Simple electrical diagnostic!
Old 12-23-2007, 01:00 PM
rice4life's Avatar
rice4life will become famous soon enough
check clutch switch too! the one at the top because there may be two if you have cruse control. if its bad theres no biggie just stick a paper clip in it and make sure u dont start it with it in gear
rice4life is offline
Old 12-23-2007, 03:19 PM
Full-time New Guy
Scottyk6's Avatar
Oo that sounds fun. What exactly does that do?
Update: got the car to start. Rolled it about four inches, and tried starting it, and it started right up. Only problem now is that I have to give it a couple of good revs to keep it at idle, or else it'll die again. Does that sound like a starter?
Scottyk6 is offline
Old 12-23-2007, 04:16 PM
QUICKVIII's Avatar
No.
Old 12-30-2007, 03:12 PM
Full Access Member
jlgrtype's Avatar
jlgrtype jlgrtype jlgrtype jlgrtype jlgrtype jlgrtype jlgrtype
have you tried to jump start it just in case.
jlgrtype is offline
Old 01-02-2008, 11:59 AM
DarkGSR's Avatar
DarkGSR is an unknown quantity at this point
Sounds like faulty ignition.
No spark, keep revs or else will die, all other electronics work.
It happened to me on my built GSR
using stock ignition?
Yes, we all know Honda's Ignitions are God-like, but I've gone threw a few of em on my build.
DarkGSR is offline
TurboEGferio
12-28-2008 10:35 AM
jdmciviceg93
12-04-2007 04:48 PM
toycivic
06-28-2006 06:08 AM
skybluecrx
11-18-2004 12:35 PM
slowr6
07-13-2004 07:33 PM
Quick Reply: Car will not start/turn
