Integra will not start!!!
Old 03-26-2009, 11:43 AM
Temporary ######
Brian_O'Connor's Avatar
Brian_O'Connor Brian_O'Connor Brian_O'Connor Brian_O'Connor Brian_O'Connor Brian_O'Connor Brian_O'Connor Brian_O'Connor Brian_O'Connor Brian_O'Connor Brian_O'Connor
Default Integra will not start!!!
I have researced and done everything I could think of. I had to replace the driver side motor mount on my 93 intgra ls with the b18. Finished and hooked the alternator back up and now it won't start. Ran GREAT the day before. Checked all the wires, fully charged battery, good starter, good alternator, and all wire are connected. I did notice that my ground wire to the battery was coroded and exposed. But wanted to make sure it wasn't something else before I replaced it. I'm using this thread as a last ditched effort before spending money I do not have right now.
Brian_O'Connor is offline
Old 03-26-2009, 11:50 AM
team703's Avatar
Default Re: Integra will not start!!!
You check the chassis ground to tranny? or any ground? you blow the ecu fuse? do your lights come on or is there no power at all? You might have blown a fuse if your alternator wire grounded out
team703 is offline
Old 03-26-2009, 11:56 AM
Temporary ######
all wires are connected, i get juice to everything else in the car, and alt wire isnt touching anything metal.
Old 03-26-2009, 12:09 PM
team703's Avatar
you turn key and nothing happens? or does it turn over and not start
team703 is offline
Old 03-26-2009, 01:51 PM
Temporary ######
i turn the key and nothing.....lights stay on, hear the starter clicking but won't turn over.
Old 03-26-2009, 05:44 PM
b18b's Avatar
b18b has disabled reputation
I'd double check that fuse box for a blown fuse. You most likely shorted that alt wire.
b18b is offline
Old 03-26-2009, 06:15 PM
oxidejunky's Avatar
oxidejunky has disabled reputation
any power to the little wire on your starter when u hit the key?
oxidejunky is offline
Old 03-26-2009, 06:24 PM
DSMs ruined my life!
DJsilkyjr's Avatar
DJsilkyjr has disabled reputation
make sure u have the ground from the starter to somewhere on the chassis of the vehicle.
DJsilkyjr is offline
Old 03-26-2009, 06:26 PM
Temporary ######
ok....will mess with it again tomorrow. thanks everyone for the input...it is greatly appreciated. will let you know if it starts tomorrow or not.
Old 03-26-2009, 06:40 PM
Eh
NaIsGay's Avatar
NaIsGay NaIsGay NaIsGay NaIsGay NaIsGay NaIsGay NaIsGay NaIsGay NaIsGay NaIsGay NaIsGay
fix the ground wire on the batt and it will probably start
NaIsGay is offline
Quick Reply: Integra will not start!!!
