93 Civic electrical problem
Old Aug 6, 2008 | 09:09 AM
luv4jdm86's Avatar
SLOoOo EJ1
luv4jdm86 has disabled reputation
about a week ago i was driving home and my car just died in the middle of the road, then i couldnt start it back up i had no lights, no cranking nothing worked at all. i had to have it towed home. But prior to that happening i was in a parking lot and my clock, radio, and power windows went out. So i dunno if i have a bad ground connection some where or whats goin on. I kno its gotta be something electrical. So any info would help thanx
Old Aug 6, 2008 | 09:15 AM
toyota_aristo's Avatar
toyota_aristo is a jewel in the roughtoyota_aristo is a jewel in the roughtoyota_aristo is a jewel in the roughtoyota_aristo is a jewel in the rough
Default Re: 93 Civic electrical problem
Check your battery terminals for corrosion. Make sure they are clean and well connected. Then maybe check your alternator connections. The bad ground is a good idea too. Good luck.
Old Aug 6, 2008 | 01:02 PM
luv4jdm86's Avatar
SLOoOo EJ1
aight thanx
Old Aug 6, 2008 | 05:15 PM
jdm240sx's Avatar
Antonio
jdm240sx has disabled reputation
yea check ur grounding and do u have a audio system?
Old Aug 7, 2008 | 11:13 AM
luv4jdm86's Avatar
SLOoOo EJ1
nah just a kenwood head unit with stock speakers lol nothin special
Old Aug 8, 2008 | 07:26 AM
DCvtec's Avatar
DCvtec has disabled reputation
using a test light check to make sure all the fuses at good... if that's all good then make sure the battery is still good. if that is all good check to see if there power at the ignition, if not then some wiring is loose or broke. if there is power make sure there is power coming out of the switch. honda have a tendency to have ignition switches go bad...
Old Aug 9, 2008 | 06:33 AM
luv4jdm86's Avatar
SLOoOo EJ1
Thumbs up Re: 93 Civic electrical problem
yea jus figured out the problem yesterday its a combination of my alternator being bad and my negative battery cable is loose on the battery. When i take the negative cable off the car cuts off so that tells me the alternator is bad. Then you gotta keep pressure on the negative cable's clamp or it wont keep a connection so im gonna change both of those and go from there. Thanx for everybody's input, the help was well needed
Old Aug 27, 2008 | 05:26 PM
luv4jdm86's Avatar
SLOoOo EJ1
Talking Re: 93 Civic electrical problem
CLOSE THREAD PLEASE, CAR FIXED
Brian01R6
Aug 9, 2008 08:18 PM
93DOHC
Sep 6, 2007 03:00 PM
C Ory
Apr 15, 2006 10:25 AM
HMBeaty
Nov 11, 2005 08:11 PM
BadBeck
Dec 12, 2003 09:46 AM
