01 R6 Electrical Problem
Old 08-08-2008, 07:11 AM
Brian01R6's Avatar
Brian01R6 has disabled reputation
Exclamation 01 R6 Electrical Problem
Looking for some help from someone good with bike electronics. My bike is dead due to some electrical issue. I was out riding, when everything shut down. The battery was cooked, so it was replaced on the side of the road, but it didn't fix it. The culprit was the regulator/rectifier. Now, the gauge back lights, blinkers, horn, tail lights, headlights all work ok. The fuel pump, starter and guages don't work. The dash shows nothing, bike doesn't turn over. So far, I have replaced a known bad regulator/rectifier and wiring, ECU/CDI and the starting circuit cut off relay. I have checked all fuses and the main switch and starter relay and they all appear to be good. Still, the problem persists. Any ideas? Am I overlooking something simple? Does the gauge assembly somehow control the rest of the bike and it might be bad? I am at a loss for ideas!!! All help welcome and very much appreciated.
Brian01R6 is offline
Old 08-08-2008, 09:40 AM
Real Random's Avatar
Default Re: 01 R6 Electrical Problem
you check the fuses?
Have the FULL manual for the bike?
Real Random is offline
Old 08-08-2008, 09:46 AM
Brian01R6's Avatar
I have a schematic and manual for the euro model, which lines up with my bike for the most part. I have checked all fuses. I am going to double-check everything after work tonight, but this will be the third time going over it. I thought for sure it was the relay or CDI/ECU, but they were both swapped out.
Old 08-09-2008, 08:18 PM
Dont Be Scared Homie
Neo Xian Wu's Avatar
http://www.r6messagenet.com/forums/r...ir-manual.html
Neo Xian Wu is offline
importfanatic
11-17-2008 06:38 PM
93DOHC
09-06-2007 03:00 PM
C Ory
04-15-2006 10:25 AM
HMBeaty
11-11-2005 08:11 PM
240dreams
06-16-2004 09:06 PM
Quick Reply: 01 R6 Electrical Problem
