4 cyl to 6 cyl question
Originally Posted by ynofun
he did not get it out of a car. was a new gm crate motor.
im interested to know why, if it was a crate motor, he didnt just go with a V8?
. i have a 4.0 jeep for sale for $2500. pm for pics if you what to save on your swap
I've done the swap myself. Here is the deal:
I'm assiming your talking about a 2.5 to 4.0 swap. The motor swap is pretty straightforward, you just need to get motor mounts from a 4.0 TJ to bolt the block on. Other than that make sure you have the wiring harness and ECU for the 4.0. The biggest factor in the swap that many people overlook is the transmission. I'm assuming you have the AX-5 manual transmission in your TJ. You will need to put in the AX-15 manual in its place. The AX-5 will not bolt up to the 4.0, and even if it did it would not be able to handle the torque. You can throw in an AW4 auto, but wiring up an automatic tranny is a pain in the ASS (I know from experience). If you have any more questions, feel free to PM me.
did you re-gear then to 410's? What setup are you runing?
As far as switching to the 4.0 from the 2.5, if i remember correctly the input on the transfercase in the 4.0s and the input on the 2.5s have different spline counts, so you would have to change the transfercases as well. Pretty sure that the driveshaft lengths are different, and if you are going to be changing driveshafts, you might as well get rid of the piece of shit D35c rear axle.
the transfercase thats mated to the AX-5 (5 spd used with 2.5's) is going to be a 21 spline. Your going to need to run the AX-15 which requires a transfercase with a 23 spline input. You can either get a whole new transfercase, or jsut swap input gears.
crazycaseyMR2
Apr 15, 2007 02:51 PM
