y8 check engine light on wont rev over 5k????
Old Jun 12, 2008 | 09:28 PM
zach byrd's Avatar
98 civic -rebuilding
zach byrd has disabled reputation
Default y8 check engine light on wont rev over 5k????
Earlier this evening I was driving my y8 ek and hit 6800rpm in third gear and the check engine light came on and the car will not rev over 5k rpm!!!! Ouch!!! Anyways I was wondering if anyone had any ideas of what could be wrong? I was thinking that my problem would have something to do with the vtech since the car redlines at 5000-5300rpm now. If anyone has any ideas it would be much appreciated. thanks
Old Jun 13, 2008 | 01:22 AM
DOHC V-TEC's Avatar
DOHC V-TEC has disabled reputation
Default Re: y8 check engine light on wont rev over 5k????
v-tech eh? lol anyway, had a problem like this with my motor. throwing codes? Your ecu can be in limp mode. mine was throwing code 13 which is baromic (sp?) pressure sensor or something-which has to do with the car adapting to different altitudes. But then I got the timing changed and ran fine again. You should also check your TPS. CHECK ECU FOR CODES 1st!!
Old Jun 13, 2008 | 04:55 AM
cleanEK's Avatar
OIL OIL OIL check it!
6CYLINDRSYMPHNY
Feb 16, 2008 02:11 PM
hitboy
Sep 24, 2007 08:53 PM
slowd16y8
Mar 27, 2006 06:49 PM
crazyb
Jul 28, 2005 07:47 AM
hitchhiker
Nov 23, 2003 04:57 PM
