Check engine light
Old Mar 25, 2006 | 07:44 PM
slowd16y8's Avatar
slowd16y8 has disabled reputation
Default Check engine light
Ok, I have a 97 EX Civic, D16y8 and a P2P ECU. Today I installed a Apexi VAFC, programmed everything according to the manual. I didn't mess with fuel curve or anything drastic. Tonight I'm driving and go from 1st to 2nd gear fine at around 6k rpm in 2nd the car feels like I hit the rev limiter which is past 7k rpms. As soon as that happened my check engine light came on. Any ideas what I may have done? or didn't do for that matter. Thanks in advance for any help or advice.
Old Mar 25, 2006 | 08:46 PM
Hatch Man(GsR)'s Avatar
I drive a coupe
Hatch Man(GsR) Hatch Man(GsR) Hatch Man(GsR) Hatch Man(GsR) Hatch Man(GsR) Hatch Man(GsR) Hatch Man(GsR) Hatch Man(GsR) Hatch Man(GsR) Hatch Man(GsR) Hatch Man(GsR)
Default Re: Check engine light
go over your wiring and make sure you wired it properly...
Old Mar 26, 2006 | 12:42 AM
sohc_mshue's Avatar
have you thought to maybe check the code?
Old Mar 26, 2006 | 06:41 AM
1lonlyboy's Avatar
hAwAiiAn808
1lonlyboy is an unknown quantity at this point
yo thats the same shit that happen to me few weeks ago.my boy test drive my car after installing a new exhaust on my si and he kinda hit the rev limiter in 2nd gear.until now my engine light still showing.ive already went over all my sensor cause the code says that my o2 sensor volts were low so ive disconnected my battery but it showed up about three hours later.
Old Mar 26, 2006 | 10:24 AM
slowd16y8's Avatar
going to recheck wires and codes will see whats going.
Old Mar 26, 2006 | 01:23 PM
slowd16y8's Avatar
Ok took car to advanced, got them to see what check engine light meant. She said it was a mapping sensor issue. Possibly a bad mapping sensor. I went home, and rewired the VAFC, cranked it up and tada no more check engine light. Prob had a bad connection or something. Thank you all for responding. I'm new to the whole honda thing, just bought this one in January so I don't know much about it but I'm learning. Thanks again
Old Mar 27, 2006 | 07:46 AM
mrzoggs-lbr's Avatar
mrzoggs-lbr is an unknown quantity at this point
http://www.honda-tech.com/zerothread?id=1171263
tells you how to tell whats wrong...just read it
Old Mar 27, 2006 | 11:07 AM
MerF's Avatar
Ghost
Originally Posted by 1lonlyboy
....the code says that my o2 sensor volts were low so ive disconnected my battery but it showed up about three hours later.
BRACE YOURSELF FOR THIS RADICAL IDEA!!!
then it's probably a real code and your O2 is bad. *gasp* Enjoy.
Old Mar 27, 2006 | 06:49 PM
CHAHONDA's Avatar
corona connessuer
lord....drag is full of rocket scientists
6CYLINDRSYMPHNY
Feb 16, 2008 02:11 PM
lilbuddjr
Dec 14, 2007 09:53 PM
93DelSlo
Sep 24, 2007 06:28 PM
Not_Blazin
Jul 30, 2003 12:35 PM
pimpinainteasy
Mar 19, 2003 10:44 AM
