Check engine light
Ok, I have a 97 EX Civic, D16y8 and a P2P ECU. Today I installed a Apexi VAFC, programmed everything according to the manual. I didn't mess with fuel curve or anything drastic. Tonight I'm driving and go from 1st to 2nd gear fine at around 6k rpm in 2nd the car feels like I hit the rev limiter which is past 7k rpms. As soon as that happened my check engine light came on. Any ideas what I may have done? or didn't do for that matter. Thanks in advance for any help or advice.
Re: Check engine light
go over your wiring and make sure you wired it properly...
have you thought to maybe check the code?
yo thats the same shit that happen to me few weeks ago.my boy test drive my car after installing a new exhaust on my si and he kinda hit the rev limiter in 2nd gear.until now my engine light still showing.ive already went over all my sensor cause the code says that my o2 sensor volts were low so ive disconnected my battery but it showed up about three hours later.
going to recheck wires and codes will see whats going.
Ok took car to advanced, got them to see what check engine light meant. She said it was a mapping sensor issue. Possibly a bad mapping sensor. I went home, and rewired the VAFC, cranked it up and tada no more check engine light. Prob had a bad connection or something. Thank you all for responding. I'm new to the whole honda thing, just bought this one in January so I don't know much about it but I'm learning. Thanks again
Originally Posted by 1lonlyboy
....the code says that my o2 sensor volts were low so ive disconnected my battery but it showed up about three hours later.
then it's probably a real code and your O2 is bad. *gasp* Enjoy. |
lord....drag is full of rocket scientists:D
