turbo civic smoking
Old Jun 20, 2007 | 06:03 PM
Jarrod's Avatar
braap braap
Default Re: turbo civic smoking
Grab the turbo shaft and push it in and out. If it moves, then it needs a rebuild.
Some shaft play up and down is ok. As long as your seals are good.
Pull the downpipe off and check to see if there is any oil residue on the exhaust side.
My wastegate used to stick from a colapsed line. It would hit 10psi and open up after vtec crossed over(around 5800) it was a loud ass popping sound and scared the fuck outta me.
It did it a couple more times and I finially figured out what it was.
Old Jun 20, 2007 | 06:08 PM
black6gen's Avatar
Turbo VTEC-E
black6gen can only hope to improve
Cool Re: turbo civic smoking
K, Ill check it out.
Old Jun 21, 2007 | 08:29 AM
DecentCivicZ6's Avatar
DecentCivicZ6 is an unknown quantity at this point
LOL. When I blew my motor I was open downpipe aswell.
This pop sounds a little crucial though. You sure you didn't hit anything?
lol damn. Yeah i didnt really hear a pop...What i was doing was following my buddys turbo civic GSR...he was about to run a Cobra on nitrous...they hit the gas i hit the gas...and about half way thru 3rd...mine didnt really go POP...it was like the chamber was full of air and it just let it all out like a BBPPPSSHHH... lol...yeah somthing like that.
Old Nov 6, 2007 | 11:47 AM
mini-meturbodx's Avatar
registeredbeerdrinkr
mini-meturbodx is an unknown quantity at this point
You are a moron!
Old Nov 6, 2007 | 01:34 PM
Sabotage10's Avatar
Sabotage10 has disabled reputation
def. sounds like a turbo. if it were the motor you would have no doubt. is it white smoke?
Old Nov 6, 2007 | 01:49 PM
4door_GSR's Avatar
4door_GSR has disabled reputation
like said above you should do a compression test and you could do a leak down test to check if the valves are sealing properly you could chesk and make shur your injectors are workn properly and not dumping fuel or if one of them isnt opning like it should it will cause detination if it goes to lean is the car tuned ? or just a back yard setup it could have been a rich to lean condition that can make funny noises some times but you should deff check your shaft play as well if you see oil in the compressor housing its possiably and more than likely your turbo if its only in your turbine housing then it may be just commin from your motor so you have some things to check out
Old Nov 7, 2007 | 06:15 AM
B-Well's Avatar
I Love to Hate
Originally Posted by mini-meturbodx
You are a moron!
Great post, really adds to the thread
I'm with jarrod, check shaft play and look to get it rebuilt. Once you've got that out of the way you can start checking other things if the rebuild did not solve the problem.
Old Nov 7, 2007 | 10:05 AM
black6gen's Avatar
Turbo VTEC-E
Old thread. Please delete.
It was the turbo. It is replaced and running strong!
audiophile24
Jul 10, 2008 06:00 PM
forced4gsix3
Want to Buy / Trade ARCHIVE
Apr 19, 2008 11:43 AM
sick89six
Feb 21, 2007 06:56 AM
Sickteg24
Jul 16, 2006 12:04 AM
simpl4dtegra
Jun 30, 2006 07:44 AM
