obd1 b16...no spark..please help!
So I have the following...
obd1 b16
obd1 gsr distributor
Background:
I was cleaning the engine bay while the car was running and I pulled a spark plug wire from the distributor cap (dont ask why because I dont know) anyway..the car died and wont start now. I know I should not have pulled the wire, but please help if you can.
I have tried the following:
checked timing (cam gears and crank pulley all line up)
checked for spark
Everything was perfect before (cap, rotor, wires, spark plugs, ecu, wiring)
I have a spare obd1 ls distributor..so maybe I can swap out the parts because it wont bolt up..or can it be something else..any help will be appreciated..Thanks!
obd1 b16
Background:
checked for spark
Re: obd1 b16...no spark..please help!
https://www.vadriven.com/forums/honda-101/1990-civic-si-jdm-b16-swap-nova-353960/
I offer $800 doh!
See if you can borrow another distributor since that seems related to the moment things went south. I'm thinking coil or ignitor in the distributor. How strong is the spark?
I offer $800 doh!
obd1 b16
Background:
checked for spark
obd1 b16
Background:
checked for spark
Everything was good before i pulled the wire off the cap. I checked for spark by using a scredriver and grounding it. I had some spark...so im not sure what other test I could run..btw ill get cel 15 sometimes. Thanks
You probably broke the plug wire internally. Code 15 would tend to back up that theory. Get some new wires and see what happens.
