please help no spark !
Old May 19, 2004 | 07:49 PM
johnny_EG's Avatar
johnny_EG is an unknown quantity at this point
Default please help no spark !
hello my friends
I was changing tranny oil for my friend's car, but I separate the speed sensor into two parts ,because I had losen the wrong srews on the speed sensor. However does that stops the car from starting. any suggestion ? I also checked the # 1 spark plug wire and there is not a single spark ?any suggestion of what could happen?
Thank you for reading it and your suggestion ! good luck!
Old May 19, 2004 | 11:37 PM
chorejas's Avatar
el Chingon
chorejas is an unknown quantity at this point
Default Re: please help no spark !
if it is a honda it should start w/o the speed sensor.
Old Jun 5, 2004 | 08:03 AM
SOHKis's Avatar
BYAAARR!!!!!
SOHKis will become famous soon enough
check fuses, check the dissy...
Old Jun 7, 2004 | 03:00 AM
c1t1d1's Avatar
c1t1d1 is an unknown quantity at this point
If you have a volt meeter take a reading after the battery to see if you getting power , the right before the altinater and after it, and so on for the starter and distributer , you will be able to see where the power is going or not getting to
Old Jun 7, 2004 | 03:59 AM
boodussi808's Avatar
ThanXz_FukYuVeryMuch
boodussi808 has disabled reputation
Car should start w/o the speed sensor (honda/acura) but vtec won't work...if you have vtec?
DaNEW240intwn
Jul 10, 2007 04:41 PM
Brycerb
Jul 7, 2006 09:08 AM
wnabfstcrx90
Sep 10, 2005 03:51 PM
Shortfuse
Jan 2, 2003 04:51 AM
