obd1 ecu codes please help
Old 04-15-2004, 07:04 PM
Devine_wind's Avatar
Devine_wind has disabled reputation
Default obd1 ecu codes please help
I would pull up honda-tech but no access due to internet filters. Well here it goes I put the jumper wire in and I get a code 9.
Then when I clear the back up fuse, and turn the car to ignition(jumper wire is still on) the SRS light will blink and stays on solid, check engine light stays on just after.
thanks for your help.
Devine_wind is offline
Old 04-16-2004, 03:36 AM
corona connessuer
CHAHONDA's Avatar
Default Re: obd1 ecu codes please help
CODE #9 is "cylinder#1 position sensor"
CHAHONDA is offline
Old 04-16-2004, 03:25 PM
crx si 2004's Avatar
crx si 2004 is an unknown quantity at this point
AKA.... DISTRIBUTOR prob needs replacing
crx si 2004 is offline
Tim-Tim
Want to Buy / Trade ARCHIVE
14
01-16-2008 07:16 PM
slowrex
04-09-2007 11:58 AM
hondazccivic
05-09-2006 08:36 AM
Dang Yo
06-28-2004 01:00 PM
Runnin13s
03-05-2004 05:41 PM
Quick Reply: obd1 ecu codes please help
