My Clutch is Slipping
Old Apr 14, 2003 | 02:48 PM
jezta17's Avatar
jezta17 is an unknown quantity at this point
hopefully where you got it installed at or if you installed it, no fluid got on the flywheel or clutch. I know that you can have that problem if some fluid gets on those surfaces, hopefully that helps.
Old Apr 14, 2003 | 02:55 PM
Greaser's Avatar
Greaser has a reputation beyond reputeGreaser has a reputation beyond reputeGreaser has a reputation beyond reputeGreaser has a reputation beyond reputeGreaser has a reputation beyond reputeGreaser has a reputation beyond reputeGreaser has a reputation beyond reputeGreaser has a reputation beyond reputeGreaser has a reputation beyond repute
Originally posted by ChoiBoy
my flywheel is different from other flywheels... its a dual mass flywheel, built to decrease engine vibration.... the flywheel was springs on it so therefore its not possible to resurface
No your clutch disc has springs on it not the flywheel. Your fly wheel is not "dual mass" thats a load of sales BS. take the stuff out, get it resurfaced and put back together, and you MIGHT not have the problem again.
Once you glaze it over, its best to replace.
Old Apr 14, 2003 | 03:52 PM
ChoiBoy's Avatar
ChoiBoy is an unknown quantity at this point
www.hmaservice.com
Go check for yourself buddy... And yes , IT is a Dual Mass Flywheel
for the pics go to :
1. service Information
2. you need to type in the model and year, 2003 Tiburon
3. On the top, Click on the technet tab
4. go into the 2002 section
5. go into the apr section
5. click on that article
If someone can host that document on this site thatll be great
Old Apr 14, 2003 | 03:53 PM
ChoiBoy's Avatar
when it first slipped it was raining.. and in the rain it slipped really bad.... but the odd thing is my clutch does not smell at all
Old Apr 14, 2003 | 04:04 PM
Greaser's Avatar
well i stand corrected after reviewing the info. i cant believe they introduced that design into a PRODUCTION vehicle.
check the manufacturer of the clutch, they may not have made it correctly. and did you replace your stock flywheel with another stock one? it may have too much "run out" on it requiring a resuface, but since you cant resurface yours you need to buy a new flywheel.
Have fun.
Old Apr 14, 2003 | 04:12 PM
ChoiBoy's Avatar
Have fun.
it was a stock flywheel... im realli in a delimma here and i do not kno wut to do i am going contact the manufacturer again ... i did use the stock flywheel ..
y cant you believe that they are using that on a production vehicles ?
Old Apr 14, 2003 | 04:16 PM
Greaser's Avatar
because in my opinion that is a poor design and a bandaid for harmonics that should have been corrected in crank weights or front pulley dampeners not flywheel dampeners.
That leads to expensive part replacement instead of just a simple 40$ resurface job. It also allows for error with aftermarket clutch companies or any mom and pop shop fix it garage. Hyundai has to account for the idiots out there with wrenches.
kinda like when Mazda put a turbo on the already hott headed rotary. warantee claim hell for them.
Old Apr 15, 2003 | 06:57 AM
CHAHONDA's Avatar
corona connessuer
hmmmmm if it were me i would look into the possibility of getting an aftermarket flywheel??? one that is a one peice unit
Old Apr 15, 2003 | 07:14 AM
ChoiBoy's Avatar
i wish it was that easy... that means i have to buy another flywheel.. possibley get a new disc if my clutch crystaliized and fuckin labor.... my labor was 600 bucks....
Old Apr 15, 2003 | 07:23 AM
CHAHONDA's Avatar
corona connessuer
good lord!!!! $600!!!!
i would have done it for like half that!!!
ThroatyStang
Dec 18, 2006 06:27 AM
arsonistt
Jul 2, 2006 03:15 PM
OneBad1.5
Mar 31, 2006 06:22 PM
tiki240
Dec 1, 2003 11:52 AM
rsxintheblood
Aug 15, 2003 09:22 AM
