ls motor problems
Old Oct 14, 2008 | 05:32 PM
witty2733's Avatar
bash'n threads
witty2733 witty2733 witty2733 witty2733 witty2733 witty2733 witty2733 witty2733
Default ls motor problems
i have a 90 ef with the ls swap and it isnt getting fire.I got the guy i got the car to come down and look at it and he said the ecu light isnt on i dont know what that means but the fuel pump isnt workin well i cant hear it but i need help please
Old Oct 15, 2008 | 01:57 AM
boostedteg's Avatar
boostedteg has disabled reputation
Default Re: ls motor problems
check you grounds on the engine
Old Oct 15, 2008 | 03:35 AM
tatmonster's Avatar
2.0
Old Oct 15, 2008 | 07:07 AM
witty2733's Avatar
bash'n threads
Il check them, i appreciate it i dont know much about it.Il check back with yal if it works or not
Old Oct 15, 2008 | 07:48 AM
UberJag's Avatar
i like kittahs
UberJag UberJag UberJag UberJag UberJag UberJag UberJag UberJag UberJag UberJag UberJag
if ur not sure fuel pump is working pop one of the injectors out and then turn the key to prime car and fuel should spray from the injector. Otherwise check ground, starter, fuses etccc. go small when diagnosing then go big.
Old Oct 15, 2008 | 11:36 AM
1rude2l's Avatar
check the thermostat ground. Also check the ground that goes to the tranny.
Old Oct 15, 2008 | 11:40 AM
JAvenger's Avatar
not a noob
JAvenger has disabled reputation
try a different main relay... it's located under the driver side dash right in front of the door hinge.
Old Oct 15, 2008 | 05:18 PM
witty2733's Avatar
bash'n threads
i dont know much bout it but is it possible for the ecu to not be on,a buddy said theres a red light on the front that lights up
94jdm_integra
Jun 29, 2008 09:26 PM
slow ass da
Jul 12, 2006 07:10 PM
dc r-spec
Dec 3, 2005 10:45 PM
hondafreak12
Oct 23, 2005 07:12 PM
Blaznkwest
Jun 16, 2005 06:51 PM
