motor problems
Old Dec 3, 2005 | 03:41 PM
dc r-spec's Avatar
dc r-spec is an unknown quantity at this point
Default motor problems
aight guys problem is this. have a 82mm ls/vtec stage 3 cams, the works. 3 days after rebuild the car was started in the morning and ran for approx. 1 min. shut off. figured out the clutch and flywheel had gone out. replaced both. finished tonight and now i will still doing the same thing run for a min and then die. the car has fuel, spark, compression, timing, everything needed. i am lost i have checked all sensor connections, all are fine. also i need to know i have a loud rod/crank knock. could this be contributed by forged products???? let me know any suggestions
Old Dec 3, 2005 | 04:00 PM
sk8rmike's Avatar
Bitches get Stitches
Default Re: motor problems
It could be contributed by a badly spec'd bottom end and spun bearings maybe? The motor should NOT be knocking.
Old Dec 3, 2005 | 10:45 PM
The real Ryan's Avatar
Type-R; Tight Car
The real Ryan has disabled reputation
A LIGHT knock is totally normal when using forged pistons when the motor is cold. Forged internals expand with heat.
As far as your problem with the motor running for a minute and then shuting off, the only thing I can think of would be the MAP sensor possibly bad thinking it is seeing possitive pressure and telling the ecu to cut the car off (which usually takes a few seconds after sensing poss. pressure).
witty2733
Oct 15, 2008 05:18 PM
94jdm_integra
Jun 29, 2008 09:26 PM
slow ass da
Jul 12, 2006 07:10 PM
hondafreak12
Oct 23, 2005 07:12 PM
Blaznkwest
Jun 16, 2005 06:51 PM
