from low to high cp
Old Jan 28, 2007 | 09:47 PM
Default Re: from low to high cp
Originally Posted by CivicGSR00t
what'cha think?
i have a extra b16 obd2 ecu. should i switch it out. i dont have alot of $$$ for a engine management unit,
any suggestions..
thanx folks
Keep the P28, it can be tuned. OBD2 ECUs cannot be chipped or tuned, so you're stuck with a stock program.
Old Jan 29, 2007 | 01:36 AM
Gman757's Avatar
f yo couch
Gman757 has disabled reputation
Look at skunk or crower for a good pair of cams. Get 11:1 if you have to. Would still be a cp boost. Get a regular or a thinner aftermarket head gasket.
Old Jan 29, 2007 | 04:32 AM
EEK's Avatar
EEK
卐 Walnuts
Originally Posted by sohc_mshue
you can go a little higher on pump if you need to. I've tuned up to 13:1 without problems. Timing just has to be conservative and detonation needs to be monitored.
he is right, sakai had a daily itr he tuned i believe it was 14:1 cr
famlyride
Dec 21, 2007 02:12 PM
88CRXHFBSTNG
Mar 31, 2005 03:46 AM
NIC668
May 19, 2003 06:37 AM
