Intercooler Sprayers Home made???
Originally posted by Boosted2003
I know theres no water in IC. But what is in the air WATER VAPOR. This is just theory(can be wrong which) , but what happens if water vapor get to cold an freezes. (I don't this could happen) It was co2 he ran. But also a fire extinguisher would work.
Originally posted by spic
the fuck are you talking about?
Same concept. You will learn something. http://www.mascoat.com/how.htm
I know what the hell you're talking about, but what the fuck does that have to do with an intercooler not performing properly?
Do you know how cold the IC would have to be and how much moisture there would have to be for ice to appear inside of an intercooler with 250*+ air flowing through it at a couple hundred miles an hour?
Teach away, guru.
Teach away, guru.
Teach away, guru.
Teach away, guru.
Trevor
Okay...for one thing, one can obtain a Hobbs pressure switch at NAPA autoparts! They can be ordered in a variety of settings for $25. To make a simple intercooler sprayer, go to dawesdevices.com. He has a page that has water injection and intercooler sprayer instructions.
I would never spray alcohol or CO2 on an intercooler. Most places do not allow water on a track. For the street, sure. I believe that Nitrous Express makes something that sprays nitrous on the intercooler, "n'tercooler" is the name.
Litlespic uses a sleeved intercooler that is made to have water or a glycol-water mix pumped through it. Water then flows through the intercooler and back down to the heat exchangers. That intercooler design does not simply get sprayed down with a water nozzle.
