h22a LAG
Old Nov 11, 2002 | 05:15 PM
  #21
Big Chris's Avatar
Big Chris is an unknown quantity at this point
I'm actually thinking of putting on my accord fuel rail and fuel injectors to see if that will fix my problem. Also gonna put some fuel injector cleaner in to see if that could possibly fix it. I'm running out of ideas man..
Old Nov 11, 2002 | 06:25 PM
  #22
20psi 240sx's Avatar
20psi 240sx is an unknown quantity at this point
the h22 came with different size injectors on different years. make sure you got a spoon ecu for the right injectors. and for gods sake, you know that its not the engine causing it to be slower. you have to know what you are doing, or be willing to put up the crap long enough to learn. btw, injector cleaner is a waste of time. unless you have always ran crappy no name brand gas, its not going to help you. try telling us what you have. what your h22? why don't you have a stock h22 ecu? are you getting any fault codes? i'll try to help you, but don't give up on it. besides the f22 is so fuckn slow!
shaun
Old Nov 11, 2002 | 06:36 PM
  #23
Big Chris's Avatar
The ECU was for an automatic H22 and I was told that if I change the chip to a manual chip I should be fine so I bought the Spoon chip. I have a 94 JDM H22a setup and I'm not getting any codes. I appreciate the help.
Old Nov 11, 2002 | 07:04 PM
  #24
let nate and ike look at it for you if you are close by. btw, nate, i'm friends with chris with h22 wagon, got a pic of your car with chris' and ike's and someone else too....:0)
Old Nov 11, 2002 | 07:09 PM
  #25
Crate's Avatar
poop
Crate Crate Crate Crate Crate Crate Crate Crate Crate Crate Crate
If i were you. i would begin eliminating variables.
1) remove the spoon chip...
2) get rid of that automatic ecu.. prolly isnt helping at all...
the i/h/e shouldnt effect anything really. thats what i got on mine.
is your motor obd1 or 2? Do you have a obd1 motor w/ a obd2 ecu?
take it back to the basics. just find yourself a stock h22 obd1 ecu. 150-250 bux. that will fix your problems prolly.
better then swapping your f22 back in...
HELL! find a friend with a GSR. GSR ecu WILL work.. dont run aroudn with it forever, but use it to see. It will run you slightly leaner down low so you WILL notice that low end you have been missing.. if that fixes it then get yourself the correct ecu.
edit: just noticed you said 94. so is your ecu from a obd2?
Old Nov 11, 2002 | 07:12 PM
  #26
Big Chris's Avatar
its an obd1 motor with an obd1 ecu
where can i find an ecu for that cheap?? i called a junkyard my area but i didn't have the part number to the ECU available and I was too lazy to take out the ECU. prolly gonna do that tomorrow.
Old Nov 11, 2002 | 07:21 PM
  #27
Crate's Avatar
poop
actually, call steve @ www.hondamotorsonline.com
its longdistance (or use a cellphone) but ask him if he has a obd1 h22 ecu laying around. he told me 250 i think for one.
Old Nov 11, 2002 | 07:27 PM
  #28
Big Chris's Avatar
thanks Crate.. I'm gonna look around my area first before I go spending $250. kinda on the poor side right now...
Old Nov 12, 2002 | 07:09 PM
  #29
s2k7's Avatar
s2k7 has disabled reputation
what year accord do you own?
that AUTO ECU definetly is not helping you one bit. I have this gut feeling that its your problem.
Old Nov 12, 2002 | 07:16 PM
  #30
Big Chris's Avatar
94 Accord EX 5spd. I actually have two.. One is gonna be stripped down for parts soon.. Its not selling on eBay...
98shlude
Aug 1, 2007 02:35 PM
black6gen
Jun 10, 2007 11:21 AM
H23Lude9
Aug 13, 2005 08:57 PM
cspur1985
Apr 13, 2005 07:05 AM
