ek Window problem Help!!!
hey guys i have a 98 civic ek couple.. out of nowhere my pass side window stop working.. i checked the fuses and even replaced the switches... then out of where it start working like once in a while maybe one day out the week it will work.. i dont know what else to replace or get.. i believe the motor must be still good if it work once in a while
thanks for the help
thanks for the help
Re: ek Window problem Help!!!
just because it works now n then doesn`t mean the motor hasn`t gone bad. my 98 would get a second wind every so often and decide to work ...then not at all etc etc. replaced motor and it worked fine.
pissedoffpopularkids
Buy a new car or upgrade to manual windows.
Also replace your window motor aluminum magnet and flush out the headlights fluid.
Should work fine then.
Unregistered Member
do a basic deductive diagnostic. work from one end of the circuit to the other and check grounds. unplug the motor from the harness and run from a straight 12 volt source. if it works fine then move up the harness to the fuse block, fuses are good so move up the harness more to the momentary switch. If the motor works off the harness and the fuses are good the switch is likely worn enough to only work intermittently of not at all. a 12v dc electrical system is very simple to diagnose. all else fails call me and ill fix it for $50...
one of my friend ran a wire from the battery to the window switch and it worked..i checked all the fuses i guess ima check the ground ....where you located if i cant fix it ill pay you pm me ur info please and location thanks guyss!!
