97 CIVIC COUPE WINDOW PROBLEM..NEED HELP ASAP!
Now I know civics are infamous for window problems so here it is....
Today as I was rolling up the passenger window and it stops half way and wont budge an inch. I pulled off the door panel and its probably safe to say its the motor/ regulator. My question is this....is there anyway I can fix the widnow so that it is closed. If the screws on the bottom on the window were accessable I could un-bolt the two and manually force it up that way but they are NOT. Anyone have any suggestions/experience with this??
I need to get this closed ASAP as I will not be one of those SQUARES with a f***in garbage bag (or any other type of bag) over my window.
THANKS in advanced vadriven
Re: 97 CIVIC COUPE WINDOW PROBLEM..NEED HELP ASAP!
Just take the regulator off, push the window up, the wedge it closed. Or just replace the motor/regulator.
