DSM problem! HELP
Old Dec 16, 2004 | 10:58 AM
AznPride's Avatar
i-vtec dohc
AznPride is an unknown quantity at this point
Default DSM problem! HELP
the car is a 95 talon tsi fwd, the clutch wont engage for sum reason and i have no clue what to do. u can start the car but if u push in the clutch and try to put it in gear it grinds and will not go in! HELP
Old Dec 16, 2004 | 11:00 AM
mbui00's Avatar
mbui00 is a splendid one to beholdmbui00 is a splendid one to beholdmbui00 is a splendid one to beholdmbui00 is a splendid one to beholdmbui00 is a splendid one to beholdmbui00 is a splendid one to beholdmbui00 is a splendid one to beholdmbui00 is a splendid one to behold
Default Re: DSM problem! HELP
Clutch slave cylinder replacement perhaps?
Old Dec 16, 2004 | 02:12 PM
HatefulMechanic's Avatar
The Pro to call.
does the clutch pedal feel low? as in, does it feel normal, or is it real weak and you have to pull it up with your foot?
if not, then the springs in the hub are broken, and you will need a clutch replacement.
make certain the hyudraulic side is working first (signs of hyd. failure are low pedal, wont return up, and no fluid in the master cylinder)
Old Dec 17, 2004 | 08:25 PM
AznPride's Avatar
i-vtec dohc
any one wanna fix it
Old Dec 17, 2004 | 08:30 PM
King Dingaling's Avatar
Big Dick Playa
King Dingaling King Dingaling King Dingaling King Dingaling King Dingaling King Dingaling King Dingaling King Dingaling King Dingaling King Dingaling King Dingaling
i can take a look at it and fix it for a small fee
Old Dec 30, 2004 | 07:55 PM
BrokeAssCrix's Avatar
ballslickem!
BrokeAssCrix BrokeAssCrix BrokeAssCrix BrokeAssCrix BrokeAssCrix BrokeAssCrix BrokeAssCrix BrokeAssCrix BrokeAssCrix BrokeAssCrix BrokeAssCrix
could be the clutch release system and is def worth starting to look there.
if that doesnt fix the problem this is a classic sympton of crankwalk.
when u push the clutch pedal, the throwout bearing pushes on the clutch plate moving the crank towards the front of the engine. now the clutch release cant move far enough to disengage the clutch. voila.. fubar.
if this is the case replace the engine, and hope it doesnt happen again. theres really no way to guarantee it wont happen again since no one really knows why it happens, the finger gets pointed to the piston oil squirters alot.
cheap insurance on these cars is to disable the clutch safety switch. that way you wont have such a heavy load on the thrust bearing during startup when theres no oil to lube that bearing, since its splash fed not pressure fed.
Old Jan 1, 2005 | 01:12 PM
LATERV8's Avatar
amount of boost
LATERV8 is an unknown quantity at this point
thats why u dont waste money on POS DSM's ur car is fucked and time to get another one period end of convo think ur crank took a nice walk
4drjdmteg
May 16, 2007 09:31 AM
1gawd
Mar 19, 2006 04:05 PM
SpoolyMcBoostin
Jun 17, 2004 08:18 PM
QwanSanchez
Apr 25, 2004 07:26 AM
EzE
Feb 15, 2004 06:58 PM
