1G dsm starting problem
Old Mar 18, 2006 | 02:34 PM
1gawd's Avatar
I DONT SPIN
1gawd has disabled reputation
Default 1G dsm starting problem
I have a 91 TSi that will not start with the key. It will turn over and start fine with a pushbutton that is wired to the starter, so I know the starter is good. All relays and ignition switch are new. With the starter lead plugged in, I can hear the relay clicking under the dash, but it will not turn over. Has anyone else ever encountered this? Any help would be great. Thanks
Old Mar 18, 2006 | 08:36 PM
Chubbs's Avatar
Chubbs is an unknown quantity at this point
Default Re: 1G dsm starting problem
if its an automatic then check your neutral safety switch, if its a 5spd, check the safety switch on the clutch pedal. its under the dash at the top of the clutch pedal
Old Mar 18, 2006 | 09:28 PM
HighPSI TSi Guy's Avatar
❒Good ❒ Better ✔Best
is there an alarm on the car?
Old Mar 19, 2006 | 02:39 PM
1gawd's Avatar
I DONT SPIN
No alarm on the car, and no valet mode in ecu. Clutch switch has now been replaced today, still same thing. Will not turn over.
Old Mar 19, 2006 | 03:50 PM
g S x's Avatar
RIP Chris Schader
g S x g S x g S x g S x g S x g S x g S x g S x g S x g S x g S x
how about the ignition fuse on the battery.
g S x's Avatar
RIP Chris Schader
try disconnecting the clutch switch all together and turn the key.
Old Mar 19, 2006 | 03:58 PM
1gawd's Avatar
I DONT SPIN
New, but it wasn't blown anyway
Old Mar 19, 2006 | 03:59 PM
1gawd's Avatar
I DONT SPIN
Tried it disconnected, then jumped the terminals together. No good. Thanks for the ideas though.
Old Mar 19, 2006 | 04:05 PM
g S x's Avatar
RIP Chris Schader
even though the relays and switch are new, doesnt mean that they work. i'd at least try exchanging them again. if that doesnt fix it, there is a burnt wire somewhere and should be diagnosed by a professional or an auto electric shop.
rockenuptown
Feb 12, 2008 08:11 AM
cleanEK
Feb 1, 2008 03:15 PM
dhanird
Jul 3, 2007 12:00 PM
S14Civic
Jun 5, 2007 08:31 PM
GlfDaddy
Sep 6, 2006 05:05 PM
