DA electrical problem
Old Nov 15, 2008 | 05:35 PM
importfanatic's Avatar
Grippin the Grain
importfanatic importfanatic importfanatic importfanatic importfanatic importfanatic importfanatic importfanatic importfanatic importfanatic importfanatic
Default DA electrical problem
93 Acura Integra LS
Ok, weird situation. So, I went to warm up my car. I started it up and noticed that my dash lights weren't on, but the gauges still function. No biggie, probably a fuse I thought. I put the car in gear and drive only a couple of feet and my cd player turns off completely and my gauges on my A-pillar goes out completely. WTF? I pull the car up by the bay door to let it sit and warm up. I get out and walk around the car and find that my fog lights and my taillights are out. My headlights still work, but they're not as bright as usual and my brake lights still work. I did a quick check (since it was dark and raining) on my fuses and none of them seem to be blown. This problem has occured before when I took out my heater motor fuse, but the heater motor fuse is in and it seems to be fine. All input will be greatly appreciated.
Old Nov 15, 2008 | 06:56 PM
Default Re: DA electrical problem
Check the wiring on the A pillar gauges. It's quite common for someone to pinch a wire against a body seam and short something out.
Old Nov 15, 2008 | 07:25 PM
DODGESPIRIT_WOW's Avatar
DODGESPIRIT_WOW has disabled reputation
u know too much
Old Nov 16, 2008 | 05:39 AM
Grippin the Grain
Will do. I'll let you know how that goes.
Old Nov 16, 2008 | 07:08 AM
Grippin the Grain
Car is fixed. I ran out and checked for pinched wires but all the wires were fine. Checked over my fuses again and found that the fuse for dashlights/tails/foglights was blown (my lighting problem). The heater motor fuse had a bad connection (my radio and A-pillar problem). Thanks for the help man.
Old Nov 16, 2008 | 01:06 PM
1aznTT's Avatar
1aznTT 1aznTT 1aznTT
It's so true. You would be INCREDIBLY surprised what a single short would do...
Old Nov 17, 2008 | 06:38 PM
Excellent. It's always nice when it's just a blown fuse. That is, as long as you can figure out why the fuse blew..
93DOHC
Sep 6, 2007 03:00 PM
C Ory
Apr 15, 2006 10:25 AM
HMBeaty
Nov 11, 2005 08:11 PM
240dreams
Jun 16, 2004 09:06 PM
BadBeck
Dec 12, 2003 09:46 AM
