Electrical Problem
Old Jun 16, 2004 | 05:30 PM
240dreams's Avatar
<3's Photography
240dreams has disabled reputation
Default Electrical Problem
Alright i was messing with the climate control and stereo harness trying to mount my boost gauge and I messed something up. The clock doesnt work, the light doesnt turn on, the chime doesnt come on anymore, my stereo doesnt work, and my windshield wipers turn on when i turn the key to ACC. Some please help me on this, i dont know much about wiring and such. Thanks in advance. Car is a 1990 240sx.
Old Jun 16, 2004 | 06:03 PM
PoisonSVT's Avatar
PoisonSVT is an unknown quantity at this point
Default Re: Electrical Problem
Im a bit confused with what the CC and the stereo and all has to do with hooking up a boost gauge. Fill me in?
As far as the chime, clock and what not Id start by checking the fuses and see if one blew due to something you did.
Let us know
Old Jun 16, 2004 | 06:09 PM
eng's Avatar
eng
Administrator
eng eng eng eng eng eng eng eng eng eng eng
Which harnesses were you messing with? This is for a 1993 S13, but I think it should be similar to your year.
__________________
Got a 1995-1996 240SX? Want a new front bumper?
Check this out. Posting on drag first to try and avoid shipping it.
Old Jun 16, 2004 | 06:27 PM
ScrewD03's Avatar
Slowest 240 EVER
ScrewD03 ScrewD03 ScrewD03 ScrewD03 ScrewD03 ScrewD03
well are you sure the fuse are ok... hey I need help too when I unlock the driver side the passenger won't unlock
Old Jun 16, 2004 | 07:28 PM
240dreams's Avatar
<3's Photography
i was trying to find locations to tap my elec boost gauge on my stereo harness and all of a sudden i get these ill effects. im checking my fuses first thing tomorrow.
I do have a question about the boost gauge tho. What is the best way to install it? I tapped power and ground from my stereo harness and it didnt work (i have no idea why)? The gauge also requires a tap for ignition and parking light. Where should i tap these.
Its sad i can do a motor swap and engine harness conversion but can properly install a boost gauge.
Old Jun 16, 2004 | 07:46 PM
projsr20det's Avatar
projsr20det projsr20det projsr20det projsr20det projsr20det projsr20det
Most of the circuits you listed are tied to "Illumination". You will be looking for a battery circuit fuse (power on even with the key off).
On my set up I tapped into the lighter circuit for the ignition signal.
Old Jun 16, 2004 | 07:52 PM
240dreams's Avatar
<3's Photography
damn im a dumbass. I messed up my TCU i believe b/c my clock isnt on and i heard this is a common problem. What color wire did you tap ur ignition to from the cigg lighter?
does anyone have a boost gauge tapped into their parking light? What wire shoudl i tap for it. I want to be able to turn on the boost gauge illumination with the parking light switch.
Old Jun 16, 2004 | 07:59 PM
I don't remember colors off the top of my head, I use a multimeter when wiring. I used the illumination tap from the heater control display.
For a quick check look at the colors on the dimmer switch and look for the same on other components that light up too.
Old Jun 16, 2004 | 08:10 PM
240dreams's Avatar
<3's Photography
if u can get the colors man id greatly appreciate it. i dont have a multimeter. the dimmer switch has like 5 wires wandering off into the dash coming from it. its gonna be a pain. Where did you tap ur power and ground from?
Old Jun 16, 2004 | 09:01 PM
I don't have a 240, but I used to work on them for a living. Most Nissans generally have the same type of set up electrically, which is why my answers are kind of vague and not specific.
Get a multimeter and maybe a Haynes manual (for the wiring diagrams, if they have them in there).
For power I used the main ignition signal from the heater controls also (I removed most of that stuff anyway). For ground, cleaned off a small area on this safety bar under the dash and used a self tapping screw (body ground).
Edit: I used 2 ignition signals for 3 aftermarket gauges. The cig lighter and heater control.
