civic reving problem
Old Feb 9, 2007 | 06:01 AM
bluetig757's Avatar
bluetig757 has a little shameless behaviour in the past
Default civic reving problem
when car is first runnign runs fine. if you wait about one minute when you push on the gas it acts like the rev limiter is at about 2300 rpms and will not go above that. but when it first starts up it will rev all the way up. change the computer not that. changed the iac valve not that either. its a 95 civic d15b7
Old Feb 9, 2007 | 06:02 AM
Slooby's Avatar
TAINT PUNCHER!
Default Re: civic reving problem
Could be a stopped up cat.
Old Feb 9, 2007 | 10:19 AM
hondub's Avatar
I fix cars
hondub is an unknown quantity at this point
i agree
Old Feb 9, 2007 | 07:51 PM
krazdracer's Avatar
krazdracer has disabled reputation
the z's(L series nissan motor) have a Trottle positionong sensor as do many cars (no idea about honda motors) and if its rainign or you just washed your car water could build up in there and prevent the leads from tlouching to let the ecu know it is WOT and my car stoppe at about 2500 rpm.
Old Mar 3, 2007 | 05:37 AM
93DelSlo's Avatar
93DelSlo has disabled reputation
could be extremely retarded ignition timing. that would cause overheating which then takes away all engine power. that was the problem when i bought my car! have you replaced timing belt, dizzy, waterpump... lately? if so timing belt could be off a tooth to do this.
Old Mar 3, 2007 | 06:43 AM
lawabidn's Avatar
lawabidn can only hope to improve
sounds wierd, but I had that happen with a dizzy once. Might wanna swap one out to check it
Old Mar 10, 2007 | 06:59 PM
greenciv05's Avatar
Liebs
greenciv05 has disabled reputation
my d16z6 did somethign like that... it would only rev to about 3000 and hit the rev limiter... i guess its som sort of limp mode... but it would do it everytime... it was the control module in the dizzy in mine.. i just replaced the whole distributor tho .. gl hope this helps
hondapwr92
Mar 14, 2008 08:35 PM
bluetig757
Aug 8, 2006 08:22 PM
Resnostyle
Nov 9, 2005 06:37 PM
