civic problem
Old Aug 4, 2006 | 05:04 PM
bluetig757's Avatar
bluetig757 has a little shameless behaviour in the past
Default civic problem
i have a 92 civic ex and if i take the battery out of the car for two days and come back it will start for about 3min and die. and will not start back up. while it is not starting it will not get a spark. i replaced the distributor and it does the same thing.
Old Aug 4, 2006 | 10:17 PM
esohsee's Avatar
I'm worse drugged
esohsee has disabled reputation
Default Re: civic problem
are you sure it doesn't have spark? if it comes on then dies i say fuel filter cause i had a problem like that before but it was a clogged fuel filter...
Old Aug 5, 2006 | 01:30 AM
nitefire's Avatar
Mad Scientist
nitefire nitefire nitefire nitefire nitefire nitefire nitefire nitefire nitefire nitefire nitefire
Does it crank over?
Old Aug 5, 2006 | 04:57 PM
bluetig757's Avatar
yeah it cranks over and i'm sure the spark is what is keeping it from starting
Old Aug 5, 2006 | 05:12 PM
Brycerb's Avatar
S-T-F-U
Brycerb Brycerb
If you are not getting spark, then it can only be a couple things: coil, Ignition Control Module, Ignition switch, battery, fuses. Get a Hanes and test each one.
Old Aug 6, 2006 | 05:30 PM
prpl-pep-eatr's Avatar
0psi
prpl-pep-eatr is an unknown quantity at this point
it could also be the ignitor
Old Aug 6, 2006 | 07:27 PM
99EJ6T's Avatar
Boosted F2B
Old Aug 8, 2006 | 07:42 PM
bluetig757's Avatar
but i'm checking spark straight from the wires and am getting nothing.
Old Aug 8, 2006 | 08:22 PM
99EJ6T's Avatar
Boosted F2B
00civicman
Jun 25, 2008 07:22 PM
bluetig757
Mar 10, 2007 06:59 PM
civiccord
Mar 4, 2007 07:44 AM
LatinoMavric13
Feb 12, 2006 09:54 AM
mikealis
Oct 10, 2005 03:57 PM
