can you boost a car w/ ITB's???
Old Oct 24, 2006 | 05:06 PM
  #71
Razmus's Avatar
Ayo Smokey!
Razmus will become famous soon enoughRazmus will become famous soon enough
Default Re: can you boost a car w/ ITB's???
Originally Posted by projekt
it's
insane testicular bashing.
LOL
Old Oct 24, 2006 | 07:56 PM
  #72
iFoam's Avatar
ladies love my foam.
Originally Posted by dahatch
i didnt read the whole thred but dont waste your time you can make over 600 on a type r/skunk manifold
Originally Posted by Fabrik8
THe point isn't ultimate power, it's the instantaneous power that ITBs give.
exactly. thank you for saying it before i did
Originally Posted by Razmus
LOL
Old Oct 26, 2006 | 08:38 PM
  #73
Shive's Avatar
I Piss Excellence
Shive has a reputation beyond reputeShive has a reputation beyond reputeShive has a reputation beyond reputeShive has a reputation beyond reputeShive has a reputation beyond reputeShive has a reputation beyond reputeShive has a reputation beyond reputeShive has a reputation beyond reputeShive has a reputation beyond reputeShive has a reputation beyond reputeShive has a reputation beyond repute
Originally Posted by Boost609
Which such a small plenum the air will want to go directly into the #1 cylinder, therefore making the ITB's virtually useless. When using a wider/larger plenum and putting the inlet closer to the middle of the runners, it makes for a substantial increase in air flow throughout all 4 cylinders, rather than having it all cram into 1 cylinder. Plus, with the larger plenum and placement of the inlet it makes the flow fairly even in the cylinders making it not such a complete bitch when it comes time to tune. I can go on and on, but I hope that sums it up for you. It's all about flow.
This Gen2 MR2 IM from Ross Machine Racing is kind of the "ideal design" as far as the inlet placement:
Edit: I say do it Caleb!
Old Oct 27, 2006 | 06:57 AM
  #74
Which such a small plenum the air will want to go directly into the #1 cylinder, therefore making the ITB's virtually useless. When using a wider/larger plenum and putting the inlet closer to the middle of the runners, it makes for a substantial increase in air flow throughout all 4 cylinders, rather than having it all cram into 1 cylinder. Plus, with the larger plenum and placement of the inlet it makes the flow fairly even in the cyliders making it not such a complete bitch when it comes time to tune. I can go on and on, but I hope that sums it up for you. It's all about flow.
I didn't catch this the first time around. What you're saying is true, but it's true for plenums in general and doesn't have anything to do with ITBs specifically. Also, what you're saying only applies to a plenum that's substantially undersized, because the engine will still draw air in through all cylinders. You're not filling a bucket with water here, you're letting air into a pump. You're only changing the pumping efficiency of the individual cylinders, and the first cylinder is more efficient in a log-type plenum, etc.
As for the MR2 plenum, it isn't that ideal either, as the air has to make a double 90 degree turn to go into the cylinders. Shouldn't be a problem until you get well into the flow range, but the point is that it's not ideal either. It would also be a lot better if it wasn't so geometric, hard angles like that on all the plenum sides isn't that great. Air is a fluid, and likes smooth radii instead of stagnant pockets at all the corners. Eddies tend to build in corners and edges like that, not especially efficient either.
Old Oct 27, 2006 | 07:17 AM
  #75
Boost609's Avatar
hype-r
Boost609 has a reputation beyond reputeBoost609 has a reputation beyond reputeBoost609 has a reputation beyond reputeBoost609 has a reputation beyond reputeBoost609 has a reputation beyond reputeBoost609 has a reputation beyond reputeBoost609 has a reputation beyond reputeBoost609 has a reputation beyond reputeBoost609 has a reputation beyond reputeBoost609 has a reputation beyond reputeBoost609 has a reputation beyond repute
Originally Posted by colexcore
here is tubbed240s intake mani for his KA-T with the ITB pleniums welded in place
I was referring to this.
Old Oct 27, 2006 | 08:04 AM
  #76
I realize that, I was discussing both of them.
bigassturbo
Engine / Exhaust / Drivetrain
Jan 28, 2009 03:24 PM
bigassturbo
Dec 6, 2008 01:29 PM
JDM_EF-9
Sep 14, 2008 10:55 AM
