can you boost a car w/ ITB's???
Old Oct 23, 2006 | 05:40 AM
  #61
iFoam's Avatar
ladies love my foam.
Default Re: can you boost a car w/ ITB's???
Originally Posted by Fabrik8
Those velocity stacks are way too close to the plenum wall and too close to each other, they might as well not be there at all. Should have gone with a smaller radius profile or a wider plenum floor.
why does it make a difference? how does it hinder performance?
Old Oct 23, 2006 | 06:16 AM
  #62
Tarzan Bakerada's Avatar
Needs more poke.
Subscribing for Fabrik8's long and detailed response.
Old Oct 23, 2006 | 06:24 AM
  #63
Boost609's Avatar
hype-r
Boost609 has a reputation beyond reputeBoost609 has a reputation beyond reputeBoost609 has a reputation beyond reputeBoost609 has a reputation beyond reputeBoost609 has a reputation beyond reputeBoost609 has a reputation beyond reputeBoost609 has a reputation beyond reputeBoost609 has a reputation beyond reputeBoost609 has a reputation beyond reputeBoost609 has a reputation beyond reputeBoost609 has a reputation beyond repute
Which such a small plenum the air will want to go directly into the #1 cylinder, therefore making the ITB's virtually useless. When using a wider/larger plenum and putting the inlet closer to the middle of the runners, it makes for a substantial increase in air flow throughout all 4 cylinders, rather than having it all cram into 1 cylinder. Plus, with the larger plenum and placement of the inlet it makes the flow fairly even in the cyliders making it not such a complete bitch when it comes time to tune. I can go on and on, but I hope that sums it up for you. It's all about flow.
Old Oct 23, 2006 | 06:37 AM
  #64
The air can't flow around the lip of the velocity stack very effectively because the walls are so close (and therefore so is most of the boundary layer) so the stacks can't 'gather' air very efficiently from all directions. You're only going to have good velocity around the center of the stack, not around the whole perimeter like you want. The radius profile on the lip on the stacks is very important in order to work well, so if you put that lip close to the other stacks and close to the wall, and you're not sitting in clean airflow, that lip might as well not be there and you could just as easily use a flat floor with a slight radius on the edge of the runners. There is a minimum spacing around the velocity stacks for them to actually have an advantage over a straight piece of tubing (of just a flat floor), it's usually 60-200% of their diameter, depending on the spacing above the plenum floor and the radius profile of the rolled lip.
Old Oct 23, 2006 | 06:44 AM
  #65
iFoam's Avatar
both very informing..
Old Oct 23, 2006 | 07:37 PM
  #66
NX2KDET's Avatar
Needs a fast car now
NX2KDET NX2KDET NX2KDET NX2KDET NX2KDET NX2KDET NX2KDET NX2KDET NX2KDET NX2KDET NX2KDET
Originally Posted by MP5
Gti-R has ITBs on his boosted sentra. PM him and ask him about tunning.
all GTI-R motors came with ITB's and a T28 BB turbo
Old Oct 24, 2006 | 12:20 PM
  #67
iFoam's Avatar
Originally Posted by babybusa
whats itb's???
it's
insane testicular bashing.
Old Oct 24, 2006 | 04:18 PM
  #68
dahatch's Avatar
dahatch is an unknown quantity at this point
i didnt read the whole thred but dont waste your time you can make over 600 on a type r/skunk manifold
Old Oct 24, 2006 | 04:27 PM
  #69
Why read the thread when you can just reply out of context?
THe point isn't ultimate power, it's the instantaneous power that ITBs give. Transport delay and plenum volume don't really exist with ITBs..
Just because it's easier to do something, it doesn't mean there aren't better reasons for doing it the harder way.
Old Oct 24, 2006 | 04:48 PM
  #70
tecnic1's Avatar
This is going to spo
tecnic1 tecnic1 tecnic1
Your a tool.
Shit is not always about what's easier, or what's "better", and things that are off the beaten path are not always a "waste of time". Some people are into this shit because of the challenge of doing something different, or because a certain design or layout is particularly interesting, not just because you can make over x hp on y part for z dollars.
next time someone tells me something is a waste of time because everyone else thinks something else is better, I'm gonna lose it.
