boost problems
Old Apr 15, 2005 | 08:28 AM
boostedgst97's Avatar
cubs 4 life
boostedgst97 has disabled reputation
Default boost problems
i recently bought a 4b turbo for my 2nd gen gst. had a fresh rebuild on it turbo had no shaft play everything was good on it. anyways the install went ok other than a few minor problems. anyways wheni put everything back on im having boost problems. im only boostin 5psi which is low for a dsm i believe. my t25 stock was 10 but maybe im worng. i have no boost controller and all my vaccum lines are correct. what is the problem and what do i need to do to reach at least 10 psi if not more.
Old Apr 15, 2005 | 01:13 PM
cubs 4 life
Default Re: boost problems
anybody
Old Apr 15, 2005 | 02:11 PM
sk8rmike's Avatar
Bitches get Stitches
did you check the o2 sensor housing on the 14b before you put it on? a lot of them have problems with the housing around the wastegate flapper cracking/blowing out little by little over time causing blowby and low boost.
Old Apr 15, 2005 | 02:47 PM
cubs 4 life
i though that to but the sensor is fine
Old Apr 15, 2005 | 03:28 PM
g S x's Avatar
RIP Chris Schader
g S x g S x g S x g S x g S x g S x g S x g S x g S x g S x g S x
when my car was stock it only boosted 5-8 psi
mestep54
Apr 18, 2008 10:05 AM
slowr6
Mar 21, 2007 01:50 PM
integrarj
Jun 8, 2006 08:34 PM
BlackSRT4
Apr 17, 2005 04:30 PM
quikeclipse
Jul 16, 2003 07:10 PM
