boost problems..
Old Apr 4, 2008 | 05:23 AM
mestep54's Avatar
mestep54 has disabled reputation
Default boost problems..
i have a 2000 jetta 1.8t witha k06 turbo and everytime it goes past 5 pounds it starts to sputter and won't go..it pisses me off..
..any ideas?...
Old Apr 4, 2008 | 05:33 AM
toyota_aristo's Avatar
toyota_aristo is a jewel in the roughtoyota_aristo is a jewel in the roughtoyota_aristo is a jewel in the roughtoyota_aristo is a jewel in the rough
Default Re: boost problems..
What else are you running? Stock ECU? Boost controller? It could be a boost cut off or fuel cut off built into the stock ECU.
Old Apr 4, 2008 | 06:48 AM
crznx2000's Avatar
crznx2000 has disabled reputation
check your spark plugs.....make sure its the right gap, and that they are still in good shape.
Old Apr 4, 2008 | 02:12 PM
mestep54's Avatar
k04 computer chip, manual boost controller,
you think bigger injectors would help?
Old Apr 4, 2008 | 06:09 PM
snarfberries's Avatar
snarfberries has disabled reputation
how many LBS are you pushing. Very good chance you need bigger injectors.
Old Apr 6, 2008 | 09:31 AM
mestep54's Avatar
21 is what it was set at when it got tuned. i know i need to get an electronic boost controller and possibly retuned?
Old Apr 6, 2008 | 10:21 AM
forced4gsix3's Avatar
forced4gsix3 has a reputation beyond reputeforced4gsix3 has a reputation beyond reputeforced4gsix3 has a reputation beyond reputeforced4gsix3 has a reputation beyond reputeforced4gsix3 has a reputation beyond reputeforced4gsix3 has a reputation beyond reputeforced4gsix3 has a reputation beyond reputeforced4gsix3 has a reputation beyond reputeforced4gsix3 has a reputation beyond repute
Boost leaks?
Old Apr 7, 2008 | 04:25 AM
mestep54's Avatar
no it's not acting like it's leaking. it'll pull hard as hell until the engine warms up.
Old Apr 7, 2008 | 04:41 PM
inboost's Avatar
inboost has a reputation beyond reputeinboost has a reputation beyond reputeinboost has a reputation beyond reputeinboost has a reputation beyond reputeinboost has a reputation beyond reputeinboost has a reputation beyond reputeinboost has a reputation beyond reputeinboost has a reputation beyond reputeinboost has a reputation beyond repute
it definatly sounds like a boost leak my golf had the same problem as you when my stock diverter valve was leakin
Old Apr 7, 2008 | 07:18 PM
mestep54's Avatar
ok cool..i think i might actually know what's causing that now..i appreciate it
